Caterpillar pistons in JD A?
TOM4055
12-13-2006 15:19:15
I heard caterpillar has pistons that are 5 3/4 that will fit in a JD A block bored out. Anyone ever tried this?-Thanks Tom
Rusty Junk TX
12-14-2006 19:14:20
 Re: Caterpillar pistons in JD A? in reply to TOM4055, 12-13-2006 15:19:15
We have tractor pulled with a couple in Hamilton, TX and they have an unstyled A with styled A crank, lengthened rods and Cat (marine I beleive)pistons. He modified the pistons and did the rods himself and baked them in his oven. A very serious Div.II pulling tractor that can play some ball in Div.III.
He told me one time "I'd rather pry on a rock with a long screw driver than a short one" talking about them two-cylinder rods over four and six cylinder rods.
Probably a good question on the tractor pulling forum.
Marcus
Mike n Mo
12-13-2006 21:03:01
I have heard of CAT pistons being used, but I don't know the particulars of wrist pin size or compression height. If you by chance are putting a stroker crank in, a Pratt & Whitney aircraft piston is available in 5.75" bore. It has a short compression height (around 2.6") and a smaller wrist pin than the Deere pin, which is easy to deal with. If you're interested in that I can get specific measurements next week. Mike
Hayfarmer
12-13-2006 19:26:22
Seems like there would be more to it than just the bore size, like the placement of the wrist pin in the piston, size of wrist pins, height of pistons. Maybe would work but why? I can't imagine Cat parts being less expensive than JD.
Tilar
12-14-2006 12:34:57
 Re: Caterpillar pistons in JD A? in reply to Hayfarmer, 12-13-2006 19:26:22
I agree with Hayfarmer, I'm pretty sure those CAT engines are gold in color for a reason.
