Clutch adjustment on a 50
Tilar
12-13-2006 14:34:52
In all the years that we've farmed with Johnny Poppers, I dont think I've ever known the proper way to adjust a hand clutch. All we've done in the past is to turn them down even until it had a little snap when engaged.
The clutch on my 50 has always jumped when I go to engage it. Is there a specific way to adjust these to get this jumping out of it?
Its getting to the point that I'm getting worried about backing over something or worse yet, someone when we go to back up to a wagon or implement.
Mike M
12-14-2006 04:44:36
 Re: Clutch adjustment on a 50 in reply to Tilar, 12-13-2006 14:34:52
I had a 50 and it was also bad like that. I tried many things,but never could get it as nice as my other tractors for some reason. Alot of times you can just get rid of the glazing with some sandpaper or I really like to take all the metal plates and driver and sandblast them.
I also tried an old trick I heard of throwing a handfull of graphite into the clutch area. It may of helped ? didn't seem to hurt ?
DSK
12-13-2006 14:54:21
The clutch facings are probably glazed,(worn smooth). You could try replacing the linings with a kit from WTR Parts in Tyndall SD. 605-589-3128. www.wtrparts.com The kit for the 50 is $95 + $8.10 shipping. The kit also contains spring washers. I'm not sure, but I think these washers are used under the adjusting nuts to dampen clutch engagement. There was a vendor out of ND selling these a few years ago for 720-730 clutches which were notorious for being jumpy, but his was a cup style washer. Ask WTR about this.
