Clutch adjustment on a 50
Tilar
12-13-2006 14:34:38
In all the years that we've farmed with Johnny Poppers, I dont think I've ever known the proper way to adjust a hand clutch. All we've done in the past is to turn them down even until it had a little snap when engaged.
The clutch on my 50 has always jumped when I go to engage it. Is there a specific way to adjust these to get this jumping out of it?
Its getting to the point that I'm getting worried about backing over something or worse yet, someone when we go to back up to a wagon or implement.
turk lilley
12-14-2006 16:13:41
 Re: Clutch adjustment on a 50 in reply to Tilar, 12-13-2006 14:34:38
Get a set of washers. Part # AR21803R from Deere. Put a washer under each adjustment nut. Will help some with the rough clutch
2cylinderlp
12-13-2006 16:43:21
I did a complete restoration on a JD 50 including all new clutch parts and found it also to be jumpy on the clutch compared to my other larger JDs. I was quite disappointed. I think there is some tendancy for the "B" style clutch to be a little more jumpy. It is a smaller diameter and therefore less angular momentum to be overcome as you engage the clutch. If you have nice clean smooth threads on the bolts and the nuts turn freely, I suppose you could engage the clutch and use an inch pound torque wrench to get them all fairly equal. I just do it by feel. But I found that the problem of jumpiness had more to do with me not being able to control the lever well enough and less to do with the adjustment. As soon as the tractor starts to move, I'm sitting there all happy with the put put sound, but I do not move exactly as the tractor does. The inertia of my own body can't help but influence how I am controlling the clutch lever as the tractor starts to move. So for me, the solution was to rework the clutch linkage in such a way so that my own imperfect ability to control the clutch lever is less of a factor. I did this mainly by working on the clutch lever pivot pin. I made it a fairly tight, almost press fit. A new pin won't get it that way, so I weld up the old pin with an acetyline torch and then machine it on a lathe. I drill a hole in the end of the pin and cross drill in the middle of where the bushing will be to allow installing a functional grease zerk. The after putting it together with a new bushing, the clutch lever ends up having a little bit of friction on the pivot pin and will hold postition where ever it is at. It feels much like the throttle that way. But then when operating the tractor, it is just a whole different ball game. Advancing the lever to where the clutch starts to grab results in a very smooth transision from standing still to coming up to the speed for whatever gear you are in. Then I just snap it in like usual. It has been such an improvement that I am doing all of mine that way now. I don't know how long it will last. I mowed all summer with the 50 and I haven't noticed it to change at all.
Tilar
12-13-2006 17:46:40
 Re: Clutch adjustment on a 50 in reply to 2cylinderlp, 12-13-2006 16:43:21
Wow, I kind of like that idea. What did you use to weld it with the torch? Wire or Brass?
I have a 40 B that I put a new clutch in. Its not as bad as the 50.
2cyldinderlp
12-13-2006 19:01:46
 Re: Clutch adjustment on a 50 in reply to Tilar, 12-13-2006 17:46:40
third party image
I just used regular steel rod for torch welding. Someone with better welding equipment may have a better way. A stick welder would probably get you by but there will likely be hard spots and slag inclusions when you go to machine it.
It is not unusual to find that the bushing for the pivot pin is worn through and that there is wear in the bore through the clutch lever also. I have welded them up on the inside with a stick welder and then re-bored.
Tilar
12-13-2006 14:36:45
 Double post?? Ignore... in reply to Tilar, 12-13-2006 14:34:38
Terry Ann Mack
12-29-2006 06:34:04
 Re: Double post?? Ignore... in reply to Tilar, 12-13-2006 14:36:45
Test
