49 b coil wiring
gmc ronnie
12-13-2006 10:29:13
can anyone tell me which wire goes where on a coil . i have a 49 jd b , with delco distributor , key switch , ect . 6-volt. where does the wires go off of the coil . do the get hooked to the on/off switch or the distributor , ect.
gmc ronnie
12-13-2006 13:15:32
 Re: 49 b coil wiring in reply to gmc ronnie, 12-13-2006 10:29:13
thanks for the info , ronnie..
John T
12-13-2006 10:53:05
If shes still at the original Positive ground, the coils lil - terminal is wired down from the IGN output terminal on the key or toggle switch (HOT when ON) while the coils other lil + terminal wires to the lil side feed through terminal on a Delco Distributor.
John T
F-I-T
12-13-2006 10:50:16
The wire from the switch goes to the "hot" coil side, and the far side terminal goes to the distributor. So, if the system is wired positive ground, the negative wire goes to the switch and continues to the - coil terminal. Then a wire from the positive coil terminal to the distributor. The idea is that the ungrounded battery terminal flows to ground via the closed points. Reverse the signs if it is negative ground.
Frank
