Pressure wash = Definitely. Sand blast = Depends on how bad the rust is and which parts they are. Thin sheet metal may warp if it is sand blasted. Painting outside in ideal conditions can produce a good paint job, However be prepared to have bugs and other trash in your paint. On the same note, Unless you have a very clean shop, you will still have trash in it. The preperation and work you do prior to starting to put on your very first coat of primer, is 70% of how your paint job will turn out. If the metal is rusted bad and its on a fairly heavy iron, Sand blasting is great. Just be prepared to at least get a coat or two of primer on it so that it doesn"t rust before you start to paint. Sheet metal that is pitted bad can be cleaned up with something like Navel Jelly. Some paint strippers will clean a little rust also. If you are wanting to get a good slick paint job, Use a filler primer and sand it between coats with something like a 400 to 600 grit wet/dry sandpaper. You can wet sand it if you want, that helps keep the dust out of your sandpaper and it will last longer. When you get ready to paint, Take a piece of paper towel or napkin, Cover your fingers with it and run your fingers with the napkin over any spots that you think may show up. If you can feel it with the tips of your fingers, It will show up in your paint. I don"t check these boards that often, but you are welcome to email me if you have any questions that dont get answers.
