jdemaris
12-13-2006 06:18:33
Re: 301A Hydraulic pump question in reply to dave Newman, 12-13-2006 04:19:34
Yeah, but you have to ascertain what pump you have. Deere part's listings have always been screwed up for small utility tractors ever since they were new. I think perhaps because the 301 industrial tractor is built on a German-Ag platform. So -there can be one of five different pumps. That being said - just about ANY industrial 300 or 301 I've ever seen - has a US built 2.4 cubic inch, eight-piston pump. And, if it was ever replaced with a brand-new complete replacement pump from Deere - the new 2.4 inch pump is foreign made and metric. The metric pumps have serial-number tags on them, the US built pumps do NOT. And, then there are the little German metric pumps that you'll often find in the Deere parts listings. They come in four piston or eight piston and are totally different than anything else. To identify, pictures are best - but these German pumps #1 do not use a splined driveshaft - it has a keyway, and #2 the pressure-adjustment is a flat-screwdriver slot and NOT a hex Allen-drive like on the US pumps. You can post back if you are not sure what pump you have - but I will assume you have a US built 2.4 cube pump - with a splined shaft and NO serial # tag. If so - look underneath where the Allen-drive hex adjuster and jam nut are - on the bottom of the pump. All that stuff comes out - and you will lose some oil. There will be a adjuster bolt, a spring, a cartridge, then the stroke-control valve spool. The next part in the lineup is held inside the pump by o-ring pressure and usually will not fall out. Usually, you have to take parts off the top of the pump to gain access, and then push it out. It is the valve-seat cartridge. It is only held in by o-rings. The stroke-control valve and seat used to be available as separate parts - but no more. You have to buy a valve and seat assembly. From Deere - for the US 2.4 c.i. pump it is a group of three part #s - RE10712 and R27166 and R41057. When installing you'll also need the o-rings F3171R, F28782, R27166, R27564, and R26448. I also suggest you buy yourself a manual destroker-valve. It makes just about any Deere start MUCH better. It has a T-handle that shuts the hydraulic pump off. Once started, you turn it back on. Very easy to install - and used to cost $5 back when I worked for Deere. Now? I'm sure more. Shut-off for the US 2.4 pump is AR33249. Shut-off for the Metric 2.4 pump is AR96625. Here's a picture of one installed and also a picture of a US build 2.4 cube pump.
