JD B Pedestal Bushing
Ken Reese
12-12-2006 16:13:26
I am slowly, slowly restoring a 1939 "B."
The grease hole in the bushing (B101R)at the bottom of the pedestal does not line up with the grease (zerk) hole in the front of the pedestal.
How can I rotate the bushing so the two holes line up. They need to line up so grease can reach the spindle, etc.?
I suspect the bushing was replaced and no attention was given to lining up the holes; hence they are offset. The current location of the bushing doesn't appear to create a problem for the parts at the bottom of the pedestal - except that grease cannot reach the spindle, thrust washer and pivot plate.
Thanks for any advice you can give me.
Ken
Jason Z in MO
12-13-2006 14:11:46
 Re: JD B Pedestal Bushing in reply to Ken Reese, 12-12-2006 16:13:26
Ken,
Hope your project is going well! Like Mike said, if it's tight pull the grease fitting and drill another hole. It would be hard to remove without distroying it.
That lower bushing should have a couple of tabs that extend down and index with the thrust washer and prevents the thrust washer from rotating. Reason I asked, in a pedestal I picked up those tabs are almost gone. I think someone wasn't paying attention when it was re-assembled at some point in time.
Keep in touch!
Jason
Mike M
12-12-2006 17:02:12
I wonder if it has turned in the housing ? You might try pulling it out to see if it is loose. If it comes out some loctite may hold it back in. If it is in there tight then just run a drill into the hole and make a new one.
Ken Reese
12-12-2006 19:17:40
 Re: JD B Pedestal Bushing in reply to Mike M, 12-12-2006 17:02:12
I, too, was thinking I could just drill a new hole. I used a brass drift to turn the bushing in the housing but it wouldn't turn. May try it again.
Thanks,
Ken
