fuel shut off on styled A
wilson
12-12-2006 15:28:53
getting styled A ready to paint Do not want fuel and gas shut off leaking on new paint. Whats the best way to rebuild valve or should Ibuy rebuild one????
DickD
12-12-2006 19:44:10
 Re: fuel shut off on styled A in reply to wilson, 12-12-2006 15:28:53
John is definitely right on not moving them once you get the leaking stopped. But if you feel you must polish the surface, then get yourself some jeweler's rouge. It isn't nearly as harsh as valve grinding compound. It works well for me. Hope this helps you.
F-I-T
12-13-2006 07:55:44
 Re: fuel shut off on styled A in reply to DickD, 12-12-2006 19:44:10
third party image
Everybody should know that to say lapping compound is akin to saying toothpaste, as there are so many different grades and products available. Check out page 2543 of the McMaster-Carr catalog. You can start coarse at 325 equivalant mesh, then move up until you have a polish that will wring tight. At over 100,000 mesh, that is darn fine!
P Browning
12-12-2006 19:33:41
Wilson -- Take a few moments to visit the JD-H Restoration Site where fuel leaking problems are discussed under the heading of FUEL SYSTEMS. And if you decide to polish the internals of the 3-way valve, just know that beast is really delicate and many have learned that valve grinding compound is a bit too harsh. At any rate, the piece I am sending you to has some alternative ideas too -- a good read. (PatB)
John T
12-12-2006 15:39:47
If youre talking about the brass 3 way valves Gas/Fuel/Off you can buy the outer seal from Mother Deere. Some folks take em apart and use like valve grind compound to lap the valve body down into the seat. Once I get em together I set mine in the Fuel (big main tank) position n tighten the outer nut tighter then Dicks Hat Band and NEVER touch them again, I use the sediment bowl shut off or an added needle valve after that.
John T
flying jd
12-13-2006 04:22:42
 Re: fuel shut off on styled A in reply to John T, 12-12-2006 15:39:47
WOW what a beautiful job!!
John T
12-13-2006 06:06:46
 Re: fuel shut off on styled A in reply to flying jd, 12-13-2006 04:22:42
Thanks, It too a lottttt ttttt of time n work and moneyyyyy to get it there. It was first restored 5 years ago so it was muchhhhh easier this second time.
John T
