JD 4400 Removing the starter
G-man1957
12-12-2006 11:35:47
Have a JD 4400 sitting in the field and checked and looks like starter is bad. Tried removing it but can't find a way to get at the bolts, even tried standing on my head in back of the motor. It's a 6 cyl inline motor. Is there anyway to get at that starter, without taking the motor area apart or motor out? And are there 2 bolts or 3 bolts holding thte starter on? And can the 4400 be pulled with out motor running? (Just to get it out of the field)
Turtle Gears
12-12-2006 18:03:24
 Re: JD 4400 Removing the starter in reply to G-man1957, 12-12-2006 11:35:47
Why not pull start it? but yes you can move it without it running but wouldn't want to go down the road that way. T.G.
Corey C
12-12-2006 13:33:41
go to your local john deere dealer and have them get you a starter wrench. Part # JDE80 That will get the starter off.
Glen in TX
12-12-2006 13:32:45
Not sure about the JD 239 diesel starter but like said the early 292 Chevy ones had 3 bolts on flange, one upper, one against block and one lower. The later 292 starter has two long bolts under starter going upwards into block. Go buy or find one of those curved obstruction wrenches usually in 9/16 - 5/8 size or JD has starter wrenches. Can also take one those cheapo extensions and weld a socket offset on it or may need to heat and bend the extension some too. Those cheap foreign tools are good for something sometimes. The 4400 parts catalog should be online too.
Turtle Gears
12-12-2006 17:56:39
 Re: JD 4400 Removing the starter in reply to Glen in TX, 12-12-2006 13:32:45
Do you meen 329? thats what my 4400 has.
Glen in TX
12-12-2006 18:10:09
 Re: JD 4400 Removing the starter in reply to Turtle Gears, 12-12-2006 17:56:39
Blue book said 239 also and 359 for 4420 ? I don't know and why I listed parts catalog too. Just 2 or 3 bolts but that one gets you everytime.
Roger in Iowa
12-12-2006 12:16:43
Is this a combine?
Turn engine by pulling on the ground drive belts. Starter may be locked or jammed on flywheel? Turning engine may release it.
It can be pulled. Just put in neutral or can be started by putting in 4th and pulling forward with clutch pedal down. Once moving let out clutch. Don't run over the puller. Will start easier if in the high side of the variable.
If a gasser, 292 chevy, there are three bolts. Actually one capscrew and two bolts. All are reached from under the seat. The bolts may have to be held from engine side. Looks like no fun.
Gotta pull my engine. Have newer one on floor to look at starter.
Roger in Iowa
