John Deere A power block
John Fredsall
12-12-2006 06:34:28
Wondering if any knows anything about a "power Block" option that I have on a A tractor. Who made it? what did it do for power? Was a water pump part of the option? Any printed info I can get. Thanks John
Earl-IL
12-12-2006 09:49:39
 Re: John Deere A power block in reply to John Fredsall, 12-12-2006 06:34:28
Hi John, Maybe Duane Larson will answer. He has researched Tractor Supply Power Blocks. I think they recommend a add on waterpump to be used with the Power Block. They also supplied them. Earl
jd b puller
12-12-2006 16:39:17
 Re: John Deere A power block in reply to Earl-IL, 12-12-2006 09:49:39
Yeah, I think they also said it should never be used with a Heisler head. Good thing the tractor pullers aren"t doing that with a bigger crank, they could break something...
TOM4055
12-12-2006 17:06:07
 Re: John Deere A power block in reply to jd b puller, 12-12-2006 16:39:17
Hey JD B puller, you know how to reach this Heisler company that works on these JD heads-Thanks Tom
jd b puller
12-12-2006 19:20:45
 Re: John Deere A power block in reply to TOM4055, 12-12-2006 17:06:07
Sorry, can't help you there, I think they were made in Eastern Iowa somewhere, but they were new castings, not modified Deere ones. I sent you an e-mail.
Mike n Mo
12-12-2006 09:20:15
It was sold by Tractor Supply Co. It was a 6" bore as compared to a 5.5" standard bore. There were 3 different one's made, a 6-1 for ser #'s up to 584,000, 6-2 for 584,000 to 648,000, and 6-3 for 648,000 up and 60's. As far as I know it didn't come with a water pump. The very last A's had a water pump on them, and earlier models could have had them added by using piece parts. I don't have any printed info on them, but wish I did. Mike
730-LP
12-12-2006 08:47:47
It was sold by the old central tractor supply co. should be 10 to 12 more HP.Is the tractor for sell? e-mail is open thanks
