Allen taperlock flywheel on 720D
part-timer
12-11-2006 14:31:36
HI guys, looking for a little advice for those of you with experience with taperlocks. WHat is the best way to get them on tight? I bought a 58 720D with taperlock, and could not keep the clutch tight. Turned out the taperlock was not on tight enough, and tightening the clutch would just walk the collet off the shaft a little more.
It would seem to me that one would have to have the clutch off to get the crank end play set, but then the tractor can't help keep the engine from spinning as you tighten the big nut.
Thanks
jddriver
12-13-2006 08:38:34
 Re: Allen taperlock flywheel on 720D in reply to part-timer, 12-11-2006 14:31:36
Dad made shims brazed to a tin can that he unrolled that went between the collet and tractor.The extra length of the the tincans stuck out from between tractor and flywheel to pull shims out.Never hit on the nut.Never hit on the nut.Hit on the webs of flywheel alternating between sides.I get very detailed instructions with every taperlock I buy.I took a truck axle that was twisted off and stuck it in a counter sunk bolt in the right end of crankshaft,I then chained with boomers to the tractor frame on front side and thru the wheel on back side.This keeps crank from bouncing
part-timer
12-13-2006 09:23:29
 Re: Allen taperlock flywheel on 720D in reply to jddriver, 12-13-2006 08:38:34
thanks. I was thinking of something similar to block the crank over. The wife made me get rid of all my scrap iron though. I told her they were all tools waiting to be discovered, but she didn't buy it. That will teach me.
part-timer
12-12-2006 15:12:53
Maybe I am not thinking about this the right way, but doesn"t a tight clutch pull the crank all the way to the right, whereas to istall the collett and flywheel you need everything to the left? Mine is a later 720D where end play is set by flywheel position. It also has a pony. Two strikes against ease of install. It is pretty easy to set end play with the collett itself, but I don"t know how you would keep it when the clutch is engaged. With the clutch on how are you guys blocking it to the left.
Finally, how do you bump the flywheel with the nut on? It would seem that hitting the nut would move the entire collett and screw up my end play.
You guys came thru with a lot of good advice, the bolt and cup idea really intrigues me. I"ve been thinking of throwing the whole flywheel in a washtub of water over the turkey fryer to get it good and hot, then istalling over a cold collett.
mjbrown
12-13-2006 04:07:54
 Re: Allen taperlock flywheel on 720D in reply to part-timer, 12-12-2006 15:12:53
You bump the flywheel on the web, the rib that goes from the center out toward the rim, out a bit from the nut.. I haven't checked to see if a bolt in the end of the crank will clear the flywheel cover.
part-timer
12-13-2006 09:17:59
 Re: Allen taperlock flywheel on 720D in reply to mjbrown, 12-13-2006 04:07:54
OK, thanks. I plan to try to get it on tomorrow.
Duane Larson
12-11-2006 20:25:56
I would emphasize the point made by others - hit the flywheel ONCE and tighten, and repeat that pattern. Hitting it twice can cause it to bounce back out.
deere chaser
12-11-2006 17:40:00
I had to put the one on my 70 with alot of hits to the big nut with a sledge hammer to keep it tight and now it doesnt come loose. I know thats not how you are supposed to do it but it works...
DSK
12-11-2006 15:56:29
The best way to hold the crank while tightening the large nut is to remove the crankcase cover and block the #1 crank throw with a block of hardwood. To use the brakes & transmission will not give a firm enough blocking and could result in broken gear teeth if you make the flyweel as tight as it should be. Hopefully your 720 is electric start. I would recommend removing the flywheel completely and cleaning the crank & flywheel splines of any oil, you don't want any lube here. Install the sleeve and set your end play at .005-.010 with the clutch engaged and the pulley blocked completely to the left. Make sure you line up the timing marks on the sleeve and crank. Install the flywheel & nut on the crank. I had a 48" wrench made for tightening the nut but a large pipewrench will work. After you have made the nut as tight as you can, take a large hammer and bump the flywheel ONE time & retighten. Repeat this bump & tighten process until you can't tighten it any more, you can't make it too tight. Taper-Locks work well, but they need to be properly installed and kept tight.
jddriver
12-12-2006 05:36:33
 Re: Allen taperlock flywheel on 720D in reply to DSK, 12-11-2006 15:56:29
Good point on blocking the crank .I have never done this in all the taper locks I have installed and have never had any ill effects.If there are two of you one need sto be hitting and the other one tightening while hitting.After I started doing it this way ,the process was sped up greatly and the flywheel seemed to go on tighter.Steve
mjbrown
12-11-2006 15:55:56
I've been working this problem for a while myself. According to Allen, tighten with a big wrench, do not pound on the big square nut. I made a wrench from 1/4' flat stock welded in a square and welded a long piece of square tube diagonally across it and offset enough to give clearance for the end of the crankshaft. I stand a piece angle iron up so the end engages a tooth on the ring gear to hold the flywheel while I tighten the nut.
I had a lot of trouble getting the end play right and finally I drilled and tapped a1/2-20 hole in the end of the crank about an inch and a half deep. I made a series of spacers I can drive with the 1/2-20 bolt to push the collett onto the crank and take up the end play. Like JD explained you have to tighten then bang the flywheel once then tighten and bang and so on until you can't get it any tighter.
After doing all that I think my collett has slipped back out a bit and I may make a cup sort of thing I can use to leave the 1/2-20 bolt in the crank end to prevent back sliding.
I also built a honkin' big flywheel puller to get the thing off when I need to.
Good Luck!
jddriver
12-11-2006 14:53:32
First you need to have the crank shoved all the wayto the left and held TIGHT!Then the tractor needs to be put in 6th and both brakes LOCKED with the clutch tighten up and engaged.Set the shims for the end play and drive the wedge on then install flywheel and we use a 55 lb broken axle shaft and one hit and tighten the big nut do this until the flywheel quits moving and the nut is tight.I am pulling this off of the top of my head and may have left out a couple of steps but that is the general ideal.Steve
