First of all, your part numbers didn't lead me to anything associated with the camshaft. I find no H241R and H141R is a clamp found on the air cleaner hose. If you are asking if you can install a camshaft from a JD-H tractor H-10,000 and up into a 39-H, the answer is probably no; at least not without some added redesign! But wisdom tells me never to say never! Both ends of the camshaft are different. For the 39-H (1000-9999) and 1940 tractors 10000 -18864, the nut on the left end is 5/8" UNF and for later tractors it is 7/8" UNF. This would indicate a shaft diameter difference, presenting a concern about the bearing that did change at the 39-40 point. This may bring a bearing search problem plus perhaps some other complications. On the pulley end, we have a vast difference, and not all of them show up on pages 8 & 9 of the PC304 parts catalog. See also pages 10 & 11. For the 39-H, the clutch drive disk fits onto the camshaft with straight splines, similar to the JD-A tractor or the JD-60. Beginning with H-10,000, the clutch disk-shaft interface is a tapered, splined joint. A close look at page 10 will reveal a couple snap rings for the 39-H only. At the very minimum, one would have to change out the clutch drive disk along with the camshaft if you try to install a later-model camshaft. And here you need to be aware that there were more than just the two camshaft versions -- especially when securing parts! Here is what I propose to you. Re-post specifically what it is that you are planning to do. State the serial number of the H donor tractor, read the part number from the camshaft in your post. Then -- with specifics on the screen, there will be some meaningful come-back commentary to you. In the meantime, consider installing a reconditioned camshaft for a 39-H tractor. One very good source is Paul's Rod & Bearing in Parkville, Missouri (816) 587-4747. This could be the most economical solution! Now -- sure as shooting, someone out there has tried this! Come in here & enlighten us. Is this a doable option? (PatB)
