4010 lights
Steve M H
12-11-2006 09:38:08
4010 light problem
When I turn on the lights they stay on about 30 seconds and then I can hear something click and they go off. The something that clicks is mounted on the starter, I am assuming that it is some sort of thermal fuse? After a short time it will re-set. I have traced all the wires to the lights, switch etc. and they do not appear to be bad. Any ideas?
Bob
12-11-2006 11:29:41
 Re: 4010 lights in reply to Steve M H, 12-11-2006 09:38:08
You didn't mention if it is a gas, LP, or diesel tractor. There are small variations in the wiring.
Below the light switch are one or two breakers that SHOULD be protecting against a lighting circuit overload.
The breaker(s) mounted on the starter are (I believe) DEERE safety add-on to protect the entire wiring system from starting a fire if there's a short.
They are NOT cheap... part # AR47710, at nearly $50.00!
There are two ways to proceed... If you have an ammeter you can connect it in the circuit at the breaker, to see what the current draw REALLY is just before the breaker trips, to see if the load really is excessive, or if the breaker is just weak.
Or, you can disconnect lighting loads one at a time, until the problem goes away, POSSIBLY locating a shorted part.
(If this is a 24-Volt diesel, it will have TWO identical circuit breakers, and the lighting load will be split more or less evenly between them.)
My GUESS is, if the breaker(s) on the dash panel below the light switch are NOT tripping, there MAY be a problem with the BIG breaker on the starter.
