Sam -- Take a minute or two to visit the JD-H Restoration Site (below) and when you get there, one-click (on the left) on GAUGES. There you will find the general trend of change over the years of the gauges. Basically, know that black-faced gauges (more or less) came in with the ending of the letter-model series. In other words, as the JD-A gave way to the 60, guages went from white to black face. Oh, you can bank on it that some of the last JD-A tractors had black faced gauges as stock ran out. The next issue is the color of the rim or bezel around the gauge. From the factory, they were painted green. This one is more of a personal preference issue than anything else. Not many out there will notice black versus green on the rims as a major talking point. A next issue is the change in emphasis from JOHN DEERE being the most prominent letters versus the GAUGE FUNCTION. Early gauges displayed JOHN DEERE in bold characters in the upper portion and the gauge function in smaller letters beneath. During the mid-40's we see a shift, placing the name of the gauge in the upper part and in larger letters, with JOHN DEERE below and in smaller print. Another issue is fonts used to make the letters. This seems to have varied as sources for gauges changed. Here again, this is a really nitty point not likely to dominate many discussions. By the way, the shape of the rim (or bezel) also seems to have changed as sources were changed. Finally, there is some difference between tractors. A water temperature gauge for a tractor with a water pump may have different temperature listings than one (say) for a Model "H" tractor. As pointed out both above and in the article I directed you too, Jerry Trcka of Evergreen Restoration is a grat source for authentic original gauge configurations for your particular tractor. (PatB)
