2010 no one can adjust shift linkage but want to b
tinman49
12-10-2006 18:10:57
I have opportunity to buy 2010 but says shifter needs adjusting no one in his area bought manual bit doesnt go into detail. Dealer his area said gears look ok but none of his mechs kno old stuff. ????? suggestions I am newby and have 640 ford should just forget green or could be fixed
tinman49
12-11-2006 16:48:05
 Re: 2010 no one can adjust shift linkage but want in reply to tinman49, 12-10-2006 18:10:57
HI and thanx for advice . Seller says takes 5 or 6 times to get it into gear or may go first time if in gear it will stay in. Says he wnt thru hyd. and fixed those .Asking 2700 its on photo ads again thanx.
John J. Otto
12-11-2006 10:16:30
most mechanics now don't know all the little things about the debuqe tractors like the clevis on the shift lever rods for adjustment or to use 30 wt oil in the gear case
Mike M
12-11-2006 05:55:41
Those that know the 2010 well around here seem to avoid them. The tractors built after the 2010 years are far better ! like a 1020,2020
TimS in Mo
12-10-2006 20:42:04
I think you need to let us know a bit more...is the tractor just hard to shift or does it pop out of gear or will it not move/shift at all?
Gas or diesel, how many hours, how are the tires? How much are they asking for it? That will help folks be able to tell you if its a good buy for a fixer upper or not..
Not sure what to tell you about the dealer's folks not knowing about old stuff, the Deere dealers around here sure seem to know them well.
