70 gas cheap overhaul
super99
12-10-2006 15:28:09
I have a 70 gas that needs overhauled really bad, won't hardly start,compression is so low. I know that to do it right I need a lot of new parts, but am cash strapped right now. I know you don't know what you got till you tear her down, but was wondering if you think I might get away with just new rings,valve job and new bearings. No serious heavy work, just want it to run decent, do a little mowing and might pull 4 row no-till planter. Last time I planted with it, I ran in 3 rd till I got to the big hills and then had to shift to 2 nd. I haven't checked on parts yet but assume they are available. Any thoughts or comments are welcome. Thanks in advance, Chris
machinery-man
12-11-2006 13:39:09
 Re: 70 gas cheap overhaul in reply to super99, 12-10-2006 15:28:09
I have done just what you"re doing. Have removed the head and did a leak test. Fill the head chamber with fluid and see if you get a leak down. If so removed spring and take a drill and grinding compound and reseat the valve and continue to use. I"ve found mostly that the pistons seem to have a lot of wear on the first ring land. You might find better used ones or use the spacer as recommended. You might even reuse your rod bearings if clearance is not excessive. There nothing wrong with a shade tree method if you achive the desired results.
machinery-man
12-11-2006 13:39:08
Lee B
12-10-2006 17:20:00
The cheap overhaul is my forte it so happens. You only need to purchase a head gasket new, the other gaskets can be done/redone with silicone rubber. I even re-use the rings by filing the old rings' surfaces with a good file, examine some new rings (any ring will do) with a 30 power loupe or other device to note the finish texture to duplicate. It's NOT rocket science but boy howdy do some people want to make you think it is. The valve job done on my 44 'A' was done courtesy a JC Whitney's lawn mower valve grinder 'kit' for $25 or so. I had to modify it some to take the huge valve stems but the carbide cutter took to the big valves like a duck takes to water.
There won't be a way to cheat on the bearing shells but do size what you need by using Plastiguage on your current bearings when taking it apart. You don't need a fancy cylinder hone or hone job done by a machine shop either. I got mine done with a $30 triple armed, spring loaded wonder from the local parts store - again it's not rocket science, don't listen to anybody who says it IS. My tractor runs strong with no smoke which is exactly what I wanted when I started out to overhaul her - cheap. Use the internet to learn about cylinder cross-hatching and Plastiguage use.
Doing it 'right' doesn't mean spending money at a one to one ratio thankfully, spending money should be done only when actually needed. Knowing when that is requires some applied common sense, and those who don't have any of THAT stuff have to spend money as their only option. Which is why I'm thinking the advice to spend money is so popular. Use oven cleaner to remove carbon with and the only real thing standing between you a strong running 70 is some dirty work.
super99
12-11-2006 02:55:12
 Re: 70 gas cheap overhaul in reply to Lee B, 12-10-2006 17:20:00
Thank you for the posts. I guess I left out the part that It uses a lot of oil and could be used to keep bugs away (fog them out). I will start this project over the winter and will keep you informed with what I run into and will be back with more questions. I ordered a overhaul video and will need to get a IT Manual. Thanks again for the input, Chris
lejo
12-10-2006 16:10:34
Does the 70 smoke badly or use lots of oil ? You didn't say so am assuming it doesn't. Therefore
why rings and bearings? Most likely it is the valves that are bad and you will need just a valve job or valve spring or two, they should be tested. I was in a situation like yours several years ago, with an old G . found one burned valve
repaced it with a good used one, ground both,myself using suction cup type.replaced two springs. Measured crank so I knew what would be required later. Compresion ok but not tops. Used that tractor for 6 years then traded it for a new model. It still had the same amount of compression the day the trade was made. Maybe I was just lucky.el.
Mike M
12-10-2006 15:42:25
Like you said you really never know how bad it is or isn't until you pull it down.
Did you try putting air pressure in the cylinders ( leak down test ) to see/hear if maybe just the valves are leaking ? This could account for alot of it ? A valve job and NEW rings will really do alot for it. You may need top ring spacers for worn grooves or wider rings ? I have put a few together with alot of cyl. bore wear right at the top few inches and they really ran good. This may work for you for awhile or longer ? unless you really work it hard .
D-Man
12-10-2006 15:40:30
You MAY get away with it but you will have to tear her down and find the facts.
