41 A pulling parts
TOM4055
12-10-2006 09:08:00
Looking for info on the best combination between pistons, block, head, crank, camshaft, to get around 50-60 horsepower. Any info will help-THANKS
mjjk
12-12-2006 15:34:58
 Re: 41 A pulling parts in reply to TOM4055, 12-10-2006 09:08:00
I ran the 6.125 pistons in a powerblock for awhile and it did a real good job for me, plus it was a cheaper setup with good results. I have a set of 6.125 piston for a powerblock for sale if anyone is interested.
TOM4055
12-12-2006 16:18:06
 Re: 41 A pulling parts in reply to mjjk, 12-12-2006 15:34:58
Would you happen to have a power block for sale too?
mjjk
12-12-2006 19:39:02
 Re: 41 A pulling parts in reply to TOM4055, 12-12-2006 16:18:06
I don't have a block, but I have rods, crank, head for sale if it would be of interest to anyone, mjjk
TOM4055
12-13-2006 15:12:47
 Re: 41 A pulling parts in reply to mjjk, 12-12-2006 19:39:02
Are the parts for sale all stock? What do you want for them? And also where are you located?
Rusty Junk TX
12-11-2006 04:02:18
Another way. Styled A crank, lengthened rods (about .400 or so), current M&W type pistons, take about .125 off the top of the block, good cam, deck the head, port it, gas manifold, DLTX 71 carb (late A gas). We run this in a Div. II 37 A on 108 fuel turning 15.5-38 tires and it gets it done in 2nd gear most of the time. Hinrichs Repair has the pistons already set up for lengthened rods and Merfeld Machine can set up the rods.
TOM4055
12-11-2006 16:05:11
 Re: 41 A pulling parts in reply to Rusty Junk TX, 12-11-2006 04:02:18
Does anyone know how I can reach Merfeld Machine?
Rusty Junk TX
12-11-2006 16:16:50
 Re: 41 A pulling parts in reply to TOM4055, 12-11-2006 16:05:11
Merfeld Machine 563-582-8710
Drew
12-10-2006 19:41:54
If you do not want to spend the $ with the power block and crankshaft route, I think you can get to 50hp, but not 60. A A3367R or A4226R head off of a late A will gain you some compression over the all-fuel head (a '41 A should have a A2325R head) With the later head along with port work, a good cam, high ratio rocker arms; you should be 50hp to the low 50's. If you want more than that, 2 Cylinder has laid out what the next steps are.
2 Cylinder
12-10-2006 19:19:01
You can reach the 50-60 horsepower range with a powerblock bored out .125 to 6 1/8" with high compression aluminum pistons and a good gas manifold with the baffles in the manifold removed and some porting work. Thats the combination I ran on a 47 John Deere A which dyno"d 55 horsepower. You can also get to that horsepower range by having the crank stroked. If you put the powerblock combination together with a stroker crank you can reach the 70-75 horsepower range, but that will start hitting your pocketbook pretty hard.
