4240 trans leak-help
vrickster
12-10-2006 04:14:29
third party image
My 4240 has 2 small leaks coming from the bottom of the trans case where the drawbar front supports attaches. I have attached a pic to show where these leaks are on both sides. Before I tear into this front support, can someone tell me more about what is wrong and what parts I would need to get these 2 leaks stopped. I sure hope it isn"t the axle housings.
G/MAN
12-10-2006 10:25:41
 Re: 4240 trans leak-help in reply to vrickster, 12-10-2006 04:14:29
Do yourself a favor and REPLACE the shaft, even if it shows very little wear. And definitely replace the bushings in the support frame AND differential housing. There's no need whatsoever for those super-duper aftermarket fix-it kits if all the worn parts are replaced and the new parts are installed correctly. If the bushings and shaft are worn, the excessive play with be taken by the seals and they'll leak again soon regardless of what kind you use. And get yourself the proper pages from the manual - the bushings have to be installed in a specific way, with the larger inside diameters (the i.d. is tapered) facing each other so that the shaft can flex properly. If you want to zip it apart and slam it together as quickly and cheaply as possible and have it leak again in a few hundred hours, you may as well keep buying hydraulic oil and floor dry. Doing it correctly and having it last several thousand hours is going to require a little bit more money and labor.
Wimpfarm
12-10-2006 05:06:52
Sounds like your load shaft seals are leaking , drain the transmission, pull the load shaft replace the seals , you used to be able to get better than deere seals from Bowling machine shop, then put back together. You need to check the shaft fore wear, really not that bad of a job .
