70 compression release
mb ohio
12-09-2006 17:01:44
70d will not come back on compression after decompress. rod seems to stick?
F-I-T
12-10-2006 15:11:19
 Re: 70 compression release in reply to mb ohio , 12-09-2006 17:01:44
third party image
I had one like that earlier this year. The shaft that runs from the left side (where the engagement lever is...pony transmission side) runs through the steering wheel pedestal/shift quadrant, through to the other side where it connects to the de-compression shaft via the little 4" lever (54). Here's what I found: the shaft is in two pieces, and it spits right behind the shift quadrant so that after you have it cranking on de-comp, and then you advance the starting lever to its crank and compression position, the spring and cam behind the quadrant along with the split shaft allows the decomp to come off yet the cranking pinion stays engaged. If you disconnect the linkage to the shaft and lever on the right side, and it is nice and free, check that the two shafts are not frozen together (3 & 47), that roller is not frozen/not turning (32), or that the spring is broken or unhooked (40).
I'll bet one of those are the culprit.
Frank
buickanddeere
12-09-2006 17:18:14
Have you taken the linkages apart, cleaned, lubricated and adjusted them, the clutch and the brake?
