1010 JD
xfarmer
12-09-2006 09:54:28
What"s so bad about a 1010 I did a search on this forum and found that 90% of you have nothing good to say about the tractor.I bought one the other day it"s in good running cond as far as part"s being hard to find my local JD can get me all the part"s I need and there is a lot of used part"s out there.I buy and sell farm tractors. I have been doing this for 20 years part time. I have worked on some of the newer tractors and when they need parts you pay big money and some parts are hard to find also.
Osage
12-10-2006 08:20:46
 Re: 1010 JD in reply to xfarmer, 12-09-2006 09:54:28
Yep, I got one too, maybe its because its a late production "gasser" of the last year they were made, but it seems like a good one.
In response to the stated issues:
#1 - Parts, so far anything that I've needed which ain't been much I've been able to get from the local dealer
#2 - Brakes, I guess I don't understand the brake issue, mine will hold the tractor solid even on a severe incline. However, if in doubt shut-er off and leave-er in gear.
#3.- Wheel hubs and axles - a chronic problem, Mine have big cast iron hubs with a big nut for spin-out rims it doesn't look like they have ever moved, God help me if I ever have to remove them.
#4 - Single seal engine sleeves. Dealer says that problem was on will very early production.
#5 - The early Roosamaster diesel pump. Again dealer says that was another early production problem, however since mine is a "gasser", I don't know.
Sure I'd like to have a newer tractor, but for the money I couldn't beat my lil' 1010.
Osage
low budget
12-10-2006 03:19:31
I've spent a lot of time on the seat of an Allis D14 and D17 and will say the JD 1010 and 2010 are no better than the competition but probably not much worse. Try getting parts for a D17 diesel.IH had hard starting glow plug diesels at the time the 1010 and 2010 were built too. Its just that the 3010 and 4010 and their successors were so much better than the competition that it makes the smaller JD of the time look much worse.
Rusty Junk Tx
12-09-2006 19:08:18
Been looking a long time for a steering worm box assembly for a 1010 tricycle row crop w/power steering. Cannot seem to locate one for that particular tractor to save my life. Am about ready to part this tractor out.
Marcus
James H in Tx
03-11-2007 18:44:49
 Re: 1010 JD in reply to Rusty Junk Tx, 12-09-2006 19:08:18
There have been some on e-bay last month. Where are you located in Texas? I"m located 40 miles northeast of Houston. There are some tractor salvage yards around here. I have a 1010RS that I"m working on.
buickanddeere
12-09-2006 17:24:39
Any gasser 1010 is usuable but late production models are better. An early diesel will likely be trouble. The last year of diesel production in the 1010 and 2010 were much improved but..... ..... . So spned nearly the same money and bring home a 30 or 40 series diesel utility tractor.
jdemaris
12-09-2006 15:27:06
 Here's a list in reply to xfarmer, 12-09-2006 09:54:28
I own a couple of 1010s - so I'm not on a "hate campaign." That being said, in my opinion, the 1010 and 2010 series is about the worst product that Deere ever made. Remember - put my statement in proper context. I am comparing them to other tractors that Deere made, not tractors made by other companies. We had to fix them when I worked at several Deere dealerships dating back to the 60s - and part of that "fixing" was attempting to improve on Deere's mistakes. #1 - I don't believe your dealer can get you every part. We couldn't get all parts even in the late 70s. Some parts - yes. Most major parts - yes. All the parts - absolutely not. Try to buy some early serial number injection nozzles for a diesel, a repair kit for a Webster Electric hydraulic pump, a diesel primer pump, etc. etc. #2 - I don't believe there was ever a 1010 or 2010 wheel tractor made with brakes that were safe enough to use. We attempted many types of alterations - but none worked well enough in the long run. #3 - Wheel tractors with separate hubs and axles - a chronic problem, constantly coming loose and ruining axle splines. #4 - Single seal engine sleeves. Deere had problems with all their single-seal-per-sleeve engines including early 350, 450s, 1020s, 2020s, etc. But - Deere came up with an update kit that fixed ALL the engines except the 1010 and 2010 series. #5 The early Roosamaster diesel pump - it was the first rotary injection pump Deere ever used - and the early pumps had many problems. And, there are many other things I won't bother to itemize. Most of the series appeared to be a product of afterthoughts and a surplus of leftover parts to get rid of. The crawlers were the best of the bunch - 1010 or 2010; 1010 ag. tractor not too bad, and the wheeled industrial stuff the absolute worst. You mention other tractor parts costing "big money." Go price a 1010 or 2010 sleeve deck. And, go try to find an aftermarket engine-kit. You won't.
-xfarmer
12-09-2006 16:32:42
 Re: Here's a list in reply to jdemaris, 12-09-2006 15:27:06
I agree the brakes are not the best but the brakes on the IH 424,444,404,504,ect are not that good my uncle bought a new 424 and always had problems with the brakes.I am not saying the 1010 and 2010 are the best tractor JD ever made but they are not the worst my friend has a 4010,3010,3020,on his farm and he has had his share of problems with them.I don't plan on keeping the tractor in fact I have it sold my neighbor has a 2010 and a 1010 he uses them every day and he never had any major problems with them.I think all tractor mgf.had good and bad but the 1010 and 2010 was not the worst JD ever made that's just my opinion.
Tx Jim
12-10-2006 04:22:22
 Re: Here's a list in reply to -xfarmer, 12-09-2006 16:32:42
Xfarmer,What JD tractor do you think is the worst built if it's not the 1010/2010's? 2840 maybe!! Tx Jim
xfarmer
12-10-2006 06:26:18
 Re: Here's a list in reply to Tx Jim, 12-10-2006 04:22:22
I don't know much about the 2840 never had one.I am not a john deere fan but I don't bad mouth them either when I farmed I had IH and AC had some problem's with them also my local JD dealer said he can get me part's as far as aftermarket part's I have a lot of trouble with them last year I had a farmall 560 the power steering pump was bad I bought a aftermarket pump it was junk it looked like it never been rebuilt so I don't have much use for aftermarket parts thats just my opinion.I don't buy junk and don't sell junk when I buy a tractor it goes in the shop and is gone over if something is broke it is fixed or if it can't be repaired it is sold as part's as far as JD's worst tractor. I never had much use the JD 2cly but I never bad mouthed them either.
Bob
12-09-2006 21:53:10
 IH 424 in reply to -xfarmer, 12-09-2006 16:32:42
INTERESTING...
I have a 424 IH, and have always been well satisfied with the brakes. I had never heard of them having bad brakes before!
xfarmer
12-10-2006 06:51:15
 Re: IH 424 in reply to Bob, 12-09-2006 21:53:10
How long have you had your 424? my uncle bought his new he had brake trouble from day one a friend of mine has a 444 he has trouble with the brakes also.I know a guy who was mowing on a hill behind his barn with a B414 IH when he was done mowing and returning to the barn the brakes failed and he ran into the barn IH has about the same brake design as the 1010 and 2010 wich are not that good.
Bob
12-10-2006 22:07:49
 Re: IH 424 in reply to xfarmer, 12-10-2006 06:51:15
I've owned the 424 for close to 20 years, never having considered it had poor brakes.
Loren NC
12-09-2006 11:29:10
I have a 1010 myself and it does the job I need it to do. However, I have passed along some of the things I don't like about it and have shared the information my dealer has told me about both the 1010 and 2010. They were very unflattering remarks to put it mildly. One would think the dealers would know. At least the ones should who have been doing this for a long time.
Bob
12-09-2006 10:20:02
AFAIK, it's the 2010 that gets "dissed" around here, far more so than the 1010.
