8000series
hugh haffner
12-08-2006 06:19:03
Are there any problems that stand out with the 8000 series John Deere tractors. Seems like I see a lot of them with injector pump problems and engine overhauls by the time they have reached 6000 hours. Are they not as durable as my old faithful 30 and 40 series tractors from the 70's and 80's.
G/MAN
12-08-2006 07:32:30
 Re: 8000series in reply to hugh haffner, 12-08-2006 06:19:03
Injector pump problems, kind of. Engine problems? Definitely not. Got several around here in the 8000-hour range that have never been touched, run like sewing machines and will blow away their factory horsepower ratings on the dyno. It's all about service and maintaining them. As far as the pumps, they can be hard on the injection pumps, namely because they run pretty high injection pressures for a pump/nozzle engines. Well over 4000 psi when using new nozzles. Over time that takes its toll on the pump. 6000 hours is probably about right for needing some pump work.
