1950 A oil pump removal
gurneejoe
12-08-2006 05:00:26
One of the thing I inherited with this tractor when I got it in August was a rapid oil drip from the pump housing area when the tractor is running. The oil pressure show high on the guage. I have been trying to figure out from the parts book and the others what and how to diconnect to get it out. I have the top plate off and I know there are some lines that have to be disconnected, but am not sure how many. I would like to avoid any obvious pitfalls if possible.
Joe
Mike M
12-08-2006 06:04:18
 Re: 1950 A oil pump removal in reply to gurneejoe, 12-08-2006 05:00:26
You may not need to drop the whole pump. Where is your leak ? If it is just in the center cover it is round and held in with 4 small bolts you can just remove that part only and leave the pump body and lines intact. Only thing you need to watch for on the center cover is to use the factory gasket as Pat mentioned and also you will need to make sure the drive coupling goes back on to drive the pump. You may need help, someone above guiding the shaft and coupling and someone below holding the cover and gears in place and guiding them up.
If you have to remove the whole pump body and all then you just need to disconnect all the lines going into it on the insides and remove the 3 larger nuts or bolts and work it down. Sometimes these stick fromm all the junk around the screen and hole and take some wiggling to get out. No need to remove the tappet assy. just still need to watch that drive coupling apon assembly.
P Browning
12-08-2006 05:53:49
Joe -- Close examination of both the JD-4 I&T Shop Service Manual and PC 675 Parts Catalog bring me to the same conclusion. There will be a minimum of six pipes to remove from the oil pump: R.H. and L.H. main bearings, tappets, governor, indicator, and the larger one to the oil filter head. Now, the wise man will take one final look at that pump prior to removal -- there should be not one of anything attached as you prepare to take it down.
It has been a very long time since I have worked on a JD-A. You have the crankcase cover off, but you may also need to loosen & pull the tappet assembly -- allowing you to slide the pushrods forward, granting the access you will need.
One note of caution: Be very watchful that (during reassembly) the fittings into the L.H. & R.H. main bearing housings are secure before attaching lines -- and that the pipe nuts turn onto those fittings with ease -- that is, they should go nearly all the way with fingers. So, if you have ANY fittings that fight you during removal, renew the fittings and repair the line nuts that mate them. I am renewing a L.H. main bearing now because a prior repairman did not bring the line nut "home" onto the fitting into the L.H. main bearing housing!
Second note of caution: So often we hear tales of woe about oil pressure being low or not being there at all after having reconditioned the pump as you are preparing to do. That innocent-looking B246R gasket between the gear (bottom) plate and the pump needs to be a very thin one. I urge folks to buy one from the JD Ag Dealer. Here is what happens -- if you install a thicker one, the oil will sort of slip by the gears and fail to reach the target destination like the main bearings, tappets, governor and (of course) the oil pressure indicator! I do not have the spec on that gasket, but it isn't much thicker than a grocery bag! In our zeal to stop leaks, we often over-size the gasket. Failure is the result that awaits the fellow making such a decision. My tack here is to use the design thickness gasket and also apply some gasket sealer on both sides. Be sure to rotate the pump several times after you draw the studs tight to ensure that gasket cement don't cause a "set" for the gears. As this concern would indicate, don't overdo it with gasket sealer. Enjoy! (PatB)
