3020 gas keeps flooding
Illinois Farmal
12-07-2006 15:34:08
I have a 3020 gas that keeps flooding. If it doesn"t start right off there"s no 2nd chance. Once it does start it usually only runs a few minutes before it dies....from being flooded I presume. If I don"t turn the gas off, it will continually drip from the carb. This fall the dealer I bought it from supposedly rebuilt it because I was having trouble keeping it running but it"s worse now than it was before. Before it just seemed to run rich all the time regardless of the adjustment. I"m not familiar with the green breed but I"m assuming the float is hanging up. How difficult are these carbs to work on? Thanks.
J.Stacey
12-09-2006 15:56:29
 Re: 3020 gas keeps flooding in reply to Illinois Farmall, 12-07-2006 15:34:08
sounds like you need to make the dealer make good on the carburator repair. Both are simple to rebuild. Sometimes it is hard the make a worn out carburator work exactly right. However, gas should never run out. Sounds like the dealership did not have someone repair the carburetor that knew what they were doing.
lonzo
12-09-2006 10:04:20
I agree with Glenn, some of them are a peace of junk and not worth the time trying to repair. i will try once and thats it.
Glen in TX
12-08-2006 20:53:48
Some of those Marvel Schebler USX carbs give continuous problems and aren't worth rebuilding and that's why even JD later replaced them with a Zenith. Try to find a Zenith carb for it.
Illinois Farmall
12-09-2006 14:00:02
 Re: 3020 gas keeps flooding in reply to Glen in TX, 12-08-2006 20:53:48
How can you tell the difference between the 2 carbs? Where would be a good place to look for a replacement and what would one expect to pay for it? I'm new to John Deere but I like the tractor....when it runs that is LOL I started it up today and it ran fine for 20 minutes until I shut it down but who knows about next time. I'm afraid to take it out because I never know when it will quit and it's a real pain to get started again. Thanks for all the info.
Roger in Iowa
12-07-2006 16:53:23
There is an accelerator pump of sorts built into the gasketing of the carburetor. If the gasket is ruptured it can suck gas and or possibly overflow constantly, I believe. Vacuum pulls gas into a chamber and when vacuum drops (acceleration by throttle or governor), gas is discharged into manifold. Check these parts for cracks or breaks.
Roger in Iowa
msb
12-07-2006 16:11:23
Hold the carb up close to your ear and turn it upside down and then right side up.If the float is free then you should be able to hear it flop back and forth as you keep turning it in your hand.If it has a steel needle and brass seat, you can sometimes restore the seat seal by using a punch held on the needle and gently tapping the punch with a hammer.If it has a neophreme(sp?) seat then I would suspect the needle is bad.Could be some of this gas additives these days and destroying the seal? Bob, you heard anything about this as a possibility?
Bob
12-07-2006 15:54:41
First, check the "float level" setting.
Other ideas:
The float may be "heavy" (have gasoline in it).
The float may be bent, hanging up against the carb body... usually you will see a bright, worn spot where contact is being made.
There may be "crud" trapped in the needle and seat, or the needle and set may be worn, rough, or "burred" so it hangs up, and doesn't close easily.
And, a COMMON problem, after the carb has been worked on... there needs to be a gasket between the seat and the carb body, AND the seat needs to be DARN tight, or the gasket may not seal, and let gas slip past the seat, just as if the needle and set wer not closing off 100%.
Just some things to look for.
