520 vegetable special
Greg Zimmerman
12-07-2006 15:15:14
Does anybody know how many 520 vegetable specials were made? Does anybody know a website you can go on to find out? Thank You Greg
Ben.So.Tex.
12-08-2006 05:09:37
 Re: 520 vegetable special in reply to Greg Zimmerman, 12-07-2006 15:15:14
I have a 730LP with longer axles and the rear cast is concaved it is not flat cast like other tractors I have. I have been told this is also a vegtable tractor and it has the high speed tranmission. Can't plow or drive to close to a fence or I hit the post.
Greg Zimmerman
12-09-2006 17:52:20
 Re: 520 vegetable special in reply to Ben.So.Tex., 12-08-2006 05:09:37
Thank You for your reply, Greg
Waterloo
12-07-2006 18:27:41
Greg,
The production numbers for 520"s were given in the July-August (2006) issue of Two-Cylinder. This is the most info I have found. The numbers are:
Single front Wheel 484
Long Rear Axles 333
9-42 Rears 73
11-42 Rears 2
Plain Rear Cover (no PTO) 10
If you find additional information I would like to hear from you. I own a 520 with a single front wheel, long axles, plain rear cover, and 11-42 rear tires.
Ten-Twenty
12-07-2006 19:36:53
 Re: 520 vegetable special in reply to Waterloo, 12-07-2006 18:27:41
Waterloo,
The info you refer to tells us ... "how Waterloo-built "20" Series Tractors were equipped during the first 13 months of production". So, the info is not complete and does not include individual serial number information showing how a particular tractor was equipped. However, the fact that during that 13-month production period there were 333 520's equipped with the long axle option tells us there were more of these tractors ("vegetable specials") built than was once thought.
Waterloo
12-07-2006 22:09:51
 Re: 520 vegetable special in reply to Ten-Twenty, 12-07-2006 19:36:53
Ten-Twenty, The time frame you noted is as stated in Two-Cylinder. However, I have been under the impression the (vegetable special) also had the 42" rear tires. There were only 73 of these built with 9-42 and only 2 were built with 11-42 rears. In the time frame noted. I agree with your statement, these were not built with the vegatable special label that has been attached. There is also a mention of these tractors in the Standard Catalog of John Deere Tractors 1917-1972 by Robert Pripps & Andrew Moreland. The photo of the tractor in the book is owned by the Keller Collection. The author states there were 40 high clearance single front wheel with long axles and 42" rears. I have no information to support the numbers noted in the Pripps book.
Ten-Twenty
12-08-2006 04:00:34
 Re: 520 vegetable special in reply to Waterloo, 12-07-2006 22:09:51
Waterloo,
Back in 1953 when Deere last officially recorded the "W" and "N" designation (50-W and 50-N), I understand the long axle option determined that designation, i.e. a Model 50 with the long axle option and 38" rears would have been designated a 50-N. That was the case also with the late-styled "BN" and "BW". A few of those long axle optioned tractors were fitted with 38" rears instead of the more common 42's.
Ten-Twenty
12-07-2006 17:38:18
Greg,
No one can tell you for sure because Deere did not keep an assembly line record of the number of 520's outfitted with the longer axle option. They also did not refer to tractors so equipped as "vegetable specials".
Greg Zimmerman
12-10-2006 05:44:39
 Re: 520 vegetable special in reply to Ten-Twenty, 12-07-2006 17:38:18
Thank You for the info. I think your right nobody know how many were built,Do hear of any prices the Vegetable specials bring if they bring more than the regular 520? Thanks Greg
