4020 jumps out of gear going down hill
Roger in Iowa
12-07-2006 08:49:22
1970 4020 with Synch Range jumps out of gear going down hill. Don't remember if it is in the low or high side of the range, i.e. 4th vs 7th, but believe 7th. Never jumps out under load.
Is it linkage or internal parts?
Roger in Iowa
gunner
12-07-2006 20:09:45
 Re: 4020 jumps out of gear going down hill in reply to Roger in Iowa, 12-07-2006 08:49:22
You may be able to simply build up the linkage and shift quadrant. My 4520 was doing the same thing and one of the old mechs at the local dealer built up the quadrant and replaced a couple linkages and no more problems and it shifts like new. MUCH cheaper than getting into the transmission.
Gerald J.
12-07-2006 09:29:22
Linkage isn't lubricated. It wears faster. The internal shifting is by a face cam, but if its not move all the way in position the gear or clutch isn't either.
If its only in the 4 7 range, its the range shift, not the synchronized gears because they are the same for all ranges. So if it pops out going down hill in 7th and its gears, it should pop out of range in 8th, 5th and 3rd.
Gerald J.
Roger in Iowa
12-07-2006 11:11:38
 Re: 4020 jumps out of gear going down hill in reply to Gerald J., 12-07-2006 09:29:22
I believe it was in all ranges, not just 7th, but 5th, and 8th also, don't remember 3rd.
Roger in iowa
Bob
12-07-2006 09:16:16
Yes. (Smarta$$ answer.)
It COULD be just a linkage adjustment, however, if it's been run that way a while, likely just touching up the linkage won't cure it.
There lots of parts in that collar shift mechanism to wear, and it all adds up towards giving trouble.
If it is popping out of gear on the topshaft, Deere updated the shift fork and other parts, which need to be updated at the same time. I don't think you can even buy the fork anymore for the old style, so, if the fork is worn or broken, you're forced into the update.
