4020 Gas thermostat
Rodd
12-06-2006 18:52:43
I have a 4020 gas... Does this engine have a thermostat ???? If it does where is it at... Thanks For you Help Guys Rodd
Bob
12-06-2006 18:59:36
 Re: 4020 Gas thermostat in reply to Rodd, 12-06-2006 18:52:43
The thermostats (key #1), are located in the top of the water fitting "risers" above the cylinder head, the water manifold has to be removed for access.
Third Party Image
Rodd
12-06-2006 19:07:01
 Re: 4020 Gas thermostat in reply to Bob, 12-06-2006 18:59:36
Bob :: Do you have to run thermostat on the 4020 gas ???/ Rodd Thanks If so what degree ??
Mike M
12-07-2006 03:48:21
 Re: 4020 Gas thermostat in reply to Rodd, 12-06-2006 19:07:01
Not only should you run the proper thermostats but also if you use the HOT/COLD manifold settings they run alot better.
Bob
12-06-2006 19:15:20
I don't have a 4020 gas, only a diesel. However, I run thermostats in ALL engines. Getting them up to operation temperature cuts down on oil dilution and moisture and sludge. The thermostats recommended by DEERE for the gas and LP gas models, part # R36847, are "spec'ed" @ 160 to 182 degrees.
