Lots of things to check. Look at the Donaldson precleaner. Its top should be domed upward. If its popped down, it acts as a choke. Mine was. Check that the choke wire actually pushes the choke full open. The sheath anchor on mine wasn't tied down near the carburetor and it was only getting it half way open. This time of year, you need carburetor heat. My gas 4020 (and I can't apply carburetor heat becauase the heat shroud on the manifold is split) runs rough on 10% ethanol. It runs smooth even without heat on unleaded regular. Plugs should be a hot heat range, not Champion. Plug wires should be copper, not carbon. Thermostats should be working to get the water temperature up to at least 180. Crankshaft advance is twice the synchroscope machine advance. I think there are enough marks to check the advance curve on the flywheel. Of course the crankshaft turns twice as fast as the distributor test machine too. Be sure the float level is correct and the float needle valve is shutting off the flow. Be sure the condenser is good. There seems to be an unreasonable fraction are bad out of the box. Check that the distributor top bushing isn't so worn that the shaft wobble is varying the timing and dwell. Be sure that you used a 6 volt coil, there's a resistor on the ignition switch to drop the voltage from the 12 volt battery. And there's an auxiliary contact on the starter solenoid to short out that resistor for starting. Be sure the coil polarity matches the battery polarity. The tractor was originally positive ground and so originally the + terminal on the coil went to the points. And like has already been posted, be sure there are no nests or critters in the intake lines. Gerald J.
