'47 B antifreeze?
KevinH
12-06-2006 08:35:33
I"m working on a styled B for a friend. Here in SC we very seldom get to 0 degreesF but do get in the teens and twenties some. What mix of antifreeze to water should I put in her and what is the capacity of the radiator and block?
**oh yeah, also, it has a small leak in the rad. and was thinking of trying one of the bars leaks products. Anyone have any opinions on which to use?
Thanks for any help. Kevin
Steve Crum
12-06-2006 21:56:31
 Re: '47 B antifreeze? in reply to KevinH, 12-06-2006 08:35:33
You may want to plan on 7 gallons in this cooling system. The service manual says the system holds 7 gallons for S/N 201,000 and up, 6 gallons for S/N 200,999 down. The A holds 8 1/2 gallons for S/N 584,000 and up, 9 1/4 gallons for S/N 499,000-583,999. But then again the Deere service manual could be wrong.
machinery-man
12-06-2006 14:02:00
I can tell you from plenty of experience the more you mess with that old radiator the worse it get, if you flush out and new water you will eventually have it leaking like a cive as all the rods will start going to pieces as they are generally deterioated expecially in the center where there was a lot of free falling perculation. My suggest would be to boil your outside the radiator or get it as hot as you can, then put your bar"s leak in water then put about the same amount of antifree in the water then start pouring into the radiator with the tractor running...making a soupy water antifreeze bars leaks combination then hope for the best. You haven"t got anything to loose and the old gay might seal off. Then don"t ever flush or mess with again. If you want to pull radiator and spend about $300 you could replace core and have it like new. The other way, you"ve got nothing to loose.
JGC
12-06-2006 13:48:47
I haven't worked on a "B" rad but I was able to repair leaks in my "D" rad by carefully cleaning and drying the leaky spots and soldering them.
The rad was out of the tractor so it was real easy to solder.
JGC
buckeye al
12-06-2006 13:18:57
CLW mentioned to mix the water & Anti Freeze because there is no water pump and later you replied that you'd be running it easily long enough to mix the two.
There's more to it than that! The anti freeze will not flow and begin to mix with the water even as the tractor heats up because the anti freeze is heavier than water. It all goes to the bottom and essentially "plugs" the system. Even with the shutter open, they'll usually boil over shortly after starting them and there goes your nice new anti freeze all over your nice new green paint. I had this happen to me once even when I poured in a gallon of AF then a water, AF then water. Even alternating, the AF still went to the bottom & it boiled over though just a little.
Ever since learning that "the hard way" I fill 'em up new by pouring in a half a jug of AF then I fill the jug back up with water, shake & pour. The second jug I pour half into the now empty jug & fill 'em both with water, shake & pour. Keep that up 'till it's full & haven't had a geyser since.
Maybe I cheat but I only mix mine to about a -20� here in western Ohio. Yes we get colder than that but it's not a problem. When they're working, I find it easier to keep the engine temp down off the high peg if it's a bit weaker than 50/50.
Good luck.
KevinH
12-06-2006 13:24:30
 Re: '47 B antifreeze? in reply to buckeye al, 12-06-2006 13:18:57
More great advice. I must admit here that the mixing I was referring to was actually the bars leak, as I've been told the coolant needs to be good and hot before it will do it's business.
Much to my 5 Red tractors chagrin, I'm learning more than I ever thought I'd need to know about Green tractors! :>
Kevin
buckeye al
12-08-2006 16:22:42
 Re: '47 B antifreeze? in reply to KevinH, 12-06-2006 13:24:30
They are all interesting in different ways. That's what I find so great about old iron!
Later.
almrm
12-06-2006 12:06:06
I used the premixed 50/50 antifreeze in my A. There is plenty of freeze protection and the corrosion resistance is factory controlled compared to my well water. The cost here in Michigan is just slightly more than 50% of the full strength stuff. Store brands are fine so you do not have to pay for the Prestone name. If I have to add it is ready to go and just like the mixture in the tractor.
Remember if you mix outside of the tractor that spilt antifreeze attracts animals including pets and is dangerous and often fatel to them in very small doses.
Mark
CLW
12-06-2006 09:16:21
Kevin, I use to put the first half antifreeze then fill with water. Then it was pointed out that most model B tractors don't have water pumps and would need to be ran for quite a while before the two mix. So now I mix it 50/50 BEFORE I put it in. That way you know from the start you have protection everywhere and not just one part of the tractor. The bars leak should work fine. I have read more than once of people puting a spoon full of black pepper in the radiator. But I think I would stick with Stop Leak or some such product.
KevinH
12-06-2006 09:48:14
 Re: '47 B antifreeze? in reply to CLW, 12-06-2006 09:16:21
I must admit I have used the black pepper on my own radiators. I put quite a bit more than a spoonful in a leaky Model A Ford. It stopped up more than a couple of leaks, but when she gets hot and steams it smells like I'm making soup! Stings the eyes too since it's a strip down with no windshield. Thanks for the advice.
Kevin
Steve Crum
12-06-2006 08:58:35
Go with the 50/50 mixture. The old girl should take about 7 gallons total (3 1/2 gallons of anti-freeze). I like to use the copper seal powder in the plastic tube. You'll need the corrosion resistance of the anti-freeze and it's good down to -34 degrees. Mix the copper seal into the 2nd gallon of warm water then dump it in. Always dump in the anti-freeze 1st.
KevinH
12-06-2006 09:49:46
 Re: '47 B antifreeze? in reply to Steve Crum, 12-06-2006 08:58:35
Thanks for the advice.. I'll give it a try this weekend. The owner is gonna run it in the local parade so it should get plenty warm enough to mix.
Kevin
Mike M
12-06-2006 13:09:12
 Re: '47 B antifreeze? in reply to KevinH, 12-06-2006 09:49:46
A parade won't get it warm enough to mix,pulling a plow will.
MIX your antifreeze 50/50 ( unless you get premixed kind )BEFORE you dump it in the tractor.
Bar's leak does a pretty good job but without a waterpump it takes alot of hard working of that tractor to mix and work right.
And that B only takes about 5 gallons an A is 7
KevinH
12-06-2006 13:11:23
 Re: '47 B antifreeze? in reply to Mike M, 12-06-2006 13:09:12
COOL..thanks for the heads up.
Kevin
