1960 430 john deere utility
Dave Slabaugh
12-05-2006 19:03:34
I am not sure how to install a tachometer on a 430 motor. My repair manual does not address this issue and I am not experienced enough to experiment. Can someone describe the location and how to install or direct me to a source of information or a drawing. Thank you for your help
Dave Slabaugh
01-07-2007 19:28:02
 Re: 1960 430 john deere utility in reply to Dave Slabaugh, 12-05-2006 19:03:34
Thank you to Henry M and Hayfarmer. your response was on the mark and the tach is in place and working. Again thank you very much.
Henry M
12-07-2006 05:58:25
Hay farmer
If your tractor was never equiped with a tack, there will be a huge nut sealing up the hole where the tach drive screws into.
If you get the drive, just screw out the nut and screw the drive in there.
Hayfarmer
12-06-2006 06:58:58
couldn't remember exactly so had to go look at mine. The tach drive is just below the distributor. If you didn't have one originally you may not have the mechanism to drive it. Take a look at a parts book if you have one or go to a dealer and see if you can get a picture.
