Confusing positive and negative grounds
Dominic Centonz
12-05-2006 17:13:46
I just bought a John Deere 60 last week at a sale. It was not getting a spark. Upon close examination, I noticed it had a 12 volt battery, with negative ground. The coil, generator and voltage regulator appeared original. I noticed the coil's negative post wire was connected to the distributor. The coil's positive post wire went to the ignition switch. Shouldn't this tractor be positive ground?
John VB
12-17-2006 12:54:37
 Re: Confusing positive and negative grounds in reply to Dominic Centonze, 12-05-2006 17:13:46
This thread made me take a look at my 620. Whatever it was originally, it is now negative ground with an alternator. The positive post of my coil is hooked to the distributor. Based on what I have read in this thread, I believe that is wrong. Am I following this correctly? Thanks.
Ravgardner
12-06-2006 05:09:25
John T is right on this. Its not funny, but the A we bought at auction had the same problem as you describe. Battery had negative ground. Coil had the positive post going to the distributor. It would spark outside the cylinder, but when wired this way, the coil may loose as many as 10,000 volts from its potential production. That could be enough to cause plugs to not fire while under compression for example. I've switched the polarity of the batery, repolarized the generator. Now I've got a running tractor.
billde
12-05-2006 20:09:11
John T is correct, the only suggestion I would have is to polarize your generator. If you determine that you want or need to change polarity later just swap leads and repolarize. If you run it unpolarized you could fry your regulator. Your coil to dist must coincide with polarity [pos grd, pos to dist- neg grd, neg to dist.] Does it still have the pressure switch at the sediment bowl?
Jdg
12-05-2006 18:42:36
DEERE 40 doesn"t know what he is saying eather.
John T
12-05-2006 18:20:56
It came from the factory at Positive ground, although some got changed either by choice or accident. If its at negative ground, then the coil SHOULD BE - to distributor and when the battery polarity got changed they would have had to swap the ammeter leads also or else it would read bass ackwards and the genny would have had to been re polarized or else it would mess up the VR and not work properly.
If youre still not getting a spark and want my troubleshooting procedure for non spark do a search under charging or my name or post back buttttt ttttt even if a coil is wired correct or reversed, IT STILL CAN SPARK albeit some weaker if reversed, but reversal alone dont cause NO SPARK AT ALL.
If it was converted from a genny to an alternator, it most likely was converetd to neg ground at that time and it MUST stay that way for 99% of the typical alternators used.
John T
Deere40
12-05-2006 17:47:54
12 volt battery and alternator ever thing should be changed to negative ground.
Dominic Centonze
12-05-2006 18:13:00
 Re: Confusing positive and negative grounds in reply to Deere40, 12-05-2006 17:47:54
This tractor does not have an alternator. Not sure what Deere40 is saying?
Bob
12-05-2006 18:17:04
 Re: Confusing positive and negative grounds in reply to Dominic Centonze, 12-05-2006 18:13:00
The tractor would have been (+) ground, originally. Having the coil hooked up backwards will NOT cause a "no-spark: situation, but WILL lessen the effectiveness of the spark at the plugs about 20% while running, perhaps being enough to cause some misfiring under load.
