JD450 year/info
AZ.Nick
12-05-2006 15:18:49
I retrieved this # JD450BC184581T off the mfg plate and the local dealer doesn't handel industrial archives ???. Can anyone help me with the year, confirm the model, and engine size/.h.p. This was the engine # *T04219D10418* and under that was 4219DT008. I'm looking at a purchase on this dozer and would appriciate any past history on it.
AZ.Nick
12-06-2006 06:34:06
 Re: JD450 year/info in reply to AZ.Nick, 12-05-2006 15:18:49
Great info. If my memory serves me correctly I believe I saw a small turbo.
Did the B every change or improve on any horsepower in a year or half year model at any time?
Is there any other way to distinguish the B from the C i.e. control levers? I do have photos.
mowr
12-05-2006 19:44:01
For 450B crawler with that ser. no., my info says 1974, 65 hp. The engine tag identifies it as a 4 cyl., 219 cu. in. engine.
HTR
12-05-2006 19:43:58
My book has it a 1974, 450B.
I don't see the 450B listed on the JD site, but here is the 450C. They are almost the same, except the C is a little more weight and has a turbo. Both have 219 engines, and are listed at the same horse power.
CH
12-06-2006 02:38:11
 Re: JD450 year/info in reply to HTR, 12-05-2006 19:43:58
There is a Big difference between a B and C. A C is a wet clutch machine.
AZ.Nick
12-06-2006 14:52:55
 Re: JD450 year/info in reply to CH, 12-06-2006 02:38:11
Thanks for the replys.
HTR do you have the link or info for the 450B?
HTR
12-06-2006 17:39:16
 Re: JD450 year/info in reply to AZ.Nick, 12-06-2006 14:52:55
They skip the 450B. Here is what they have.
AZ.Nick
12-08-2006 09:23:02
 Re: JD450 year/info in reply to HTR, 12-06-2006 17:39:16
Do you have any idea why the 450B was skipped and where to get specs?
AZ.Nick
12-06-2006 18:26:59
The original decals say JD 450 B on it, but the serial # says JD450BC, then the rest of the # as I gave in the first email above. I'm kinda confused now because this is big difference between wet & dry clutches????
