It Starts! JD70!!!!
txasylum
12-05-2006 15:01:07
Good news! It started. The timing in the manual says to go 5 degrees to 10 degrees ATDC for LPG. Well, that is where I have been trying to start it all along. Today, I decided to go 10 Degrees BTDC. Bam! It fired up. So the timing was off somewhere along the line. I can't go with the manual on this one.
I'm so relieved. I really appreciate everyone's help on this. Now that I know it runs, I am going to start stripping it down to clean and paint (something I'm better at doing).
Thanks
Bob
buickanddeere
12-06-2006 19:30:22
 Re: It Starts! JD70!!!! in reply to txasylum, 12-05-2006 15:01:07
I didn't think of this until reading another post. Which side of the coil is connected to the points? Which battery post is connected to chassis?
txasylum
12-06-2006 19:45:16
 Re: It Starts! JD70!!!! in reply to buickanddeere, 12-06-2006 19:30:22
Negative on both questions.
txasylum
12-06-2006 19:46:37
 Re: It Starts! JD70!!!! in reply to txasylum, 12-06-2006 19:45:16
Correction, the battery positive is go the chasis.
buickanddeere
12-07-2006 17:44:55
 Re: It Starts! JD70!!!! in reply to txasylum, 12-06-2006 19:46:37
Ah ha..... the coil is wired backwards and causing a weak spark. Swap the coil to match the battery. Battery + to chassis, so coil + to points.
Ben.So.Tex.
12-06-2006 08:04:00
Good deal, Sometime it just takes alittle looking back and thinking. Keep her popper.
Good Luck Ben
DRL
12-05-2006 19:58:04
Super!! Sometimes it just takes stepping back and re-thinking things. Glad that it was something as simple as that. Put some pics on here when you get her all nice and shiney.
txasylum
12-05-2006 20:07:07
 Re: It Starts! JD70!!!! in reply to DRL, 12-05-2006 19:58:04
With the colder temps now, it may be a few months before I can paint.
Thanks for the help.
Glen in TX
12-05-2006 19:47:13
Glad it's finally going Bob. Guess that means I can't come down there and buy it cheap now lol. I think Mike M is conerned about the fine tuning before painting because you might find some other things have come apart to get timing right on like it should be like governor or cam gears. Might only be someone put dist back on and had it off too or could be a wrong dist cap.
txasylum
12-05-2006 20:08:43
 Re: It Starts! JD70!!!! in reply to Glen in TX, 12-05-2006 19:47:13
How long can I run this on no water pump? I may try to run it very short just to check out the hydralics and gears. Also, I do plan on checking the clearance on the lifters when I take the tractor apart.
Bob
Mike M
12-06-2006 05:56:09
 Re: It Starts! JD70!!!! in reply to txasylum, 12-05-2006 20:08:43
I would not run it too long without somekinda coolant in it. Can you put duct tape or something ? some plywood bolted on ? over the waterpump hole and at least try to get the head and block full of water ? at least to top of head ? this will help prevent a hot spot.
txasylum
12-06-2006 09:38:16
 Re: It Starts! JD70!!!! in reply to Mike M, 12-06-2006 05:56:09
Maybe I will just put the pump back on and fill it with water just to run it for a bit.
Farmerboy
12-05-2006 19:11:12
Hey congrats! I've been quiet on your last few questions 'cause I'm not so good at the mechanicals yet but had read with interest your troubles and other responses. I had posted when you were thinking of buying it. Did you get the G as well?
When am I gonna see the "before" pics on here you promised?
txasylum
12-05-2006 20:06:14
 Re: It Starts! JD70!!!! in reply to Farmerboy, 12-05-2006 19:11:12
I didn't get the G yet. I figured I better work on one at a time. But the G is still available.
Bob
texas popper
12-06-2006 08:34:47
 Re: It Starts! JD70!!!! in reply to txasylum, 12-05-2006 20:06:14
Bob,
You said the G is still for sale? Would you mind telling us more about it and who to contact if you don't want it? Thanks!
txasylum
12-06-2006 09:37:30
 Re: It Starts! JD70!!!! in reply to texas popper, 12-06-2006 08:34:47
It is a 1953 (I think) G, but it has been converted over to propane. Tires are rotted and it hasn't run for over 10 years. I'll let you know if I don't buy it, but it will be after I get this 70 done.
CLW
12-05-2006 17:52:40
Way to go Bob. I think you will like the 70LP.
cam2
12-05-2006 16:30:45
NOTHING RUNS LIKE A DEERE, DONT SHUT IT OFF WHILE YOUR TEARING HER DOWN AND PAINTING IT TO INSURE IT ILL GO AGAIN. HA HA HA
txasylum
12-05-2006 16:51:37
 Re: It Starts! JD70!!!! in reply to cam2, 12-05-2006 16:30:45
It was all a timing thing. That is what I suspected since I replace most everything else and the compression was strong. Just had to play with her a little to get her going.
Mike M
12-05-2006 15:28:24
I'd rather see it more close to TDC so it doesn't kick back and bust the starter nose !
txasylum
12-05-2006 15:31:33
 Re: It Starts! JD70!!!! in reply to Mike M, 12-05-2006 15:28:24
I'm just happy it started. ONce I get it painted and put back together, I will have to fine tune the timing.
Bob
Mike M
12-05-2006 15:39:27
 Re: It Starts! JD70!!!! in reply to txasylum, 12-05-2006 15:31:33
I would also think one would want to run it some more and fine tune before painting ? But to each his own ?
Alex-41JDb
12-05-2006 21:24:43
 Re: It Starts! JD70!!!! in reply to Mike M, 12-05-2006 15:39:27
Im going to agree with Mike here. You are going to put all kinds of scratches in the pretty paint job fixing this thing up right. Exspecially since it sounds like you might have some internal timing issues. But it is your tractor so have at it :)
txasylum
12-05-2006 16:07:45
Reason I'm not running it more is because I have a new water pump sitting in the garage. I dont' want to put it on and fill the tractor with water just to drain it. I am going to take the remainder of the front parts off. My primary concern was to get it running before painting.
