JD 40 Max Weight Load on 3 Point Hitch?
Russ B
12-05-2006 12:18:53
My friend is considering purchasing a PTO-driven Chipper that will be mounted on the 3 point hitch on his 1953 JD 40 tractor. The chipper weighs approximately 800 pounds, and wondering if the tractor can lift it properly? The front wheels have wheel weights and we have used a 3-point hitch-mounted rotary cutter and small harrow disk previously. I have the Operator's Manual, but can not find a maximum load specification for the hitch.
Thanks for your help,
Russ
Henry M
12-06-2006 04:56:43
 Re: JD 40 Max Weight Load on 3 Point Hitch? in reply to Russ B, 12-05-2006 12:18:53
Russ
I don't know what the rating is but I routinely use a 750 lb landscape blade on the 420 and it shows no sign of strain when it picks it up.
I don't have the front weighted but keep it close to the ground when getting into steep hills like the pond dam and am ready to drop it if the front wheels get too light.
