1948 John Deere B
Ron Avery
12-05-2006 08:38:57
Hello,
I have a 1948 model b that is running rough. When at idle, you can stand there and watch the governor constantly moving the throttle back and forth. I have replaced the mag, and the carb and it still does it. Can someone give me some advice?
Thanks,
Ron
Dave 2N
12-05-2006 12:16:00
 Re: 1948 John Deere B in reply to Ron Avery, 12-05-2006 08:38:57
Can't give you any better information than what John T gave you other than to say that in my experience (50 B, 52 B, 48 A and 54 70) the carb has been the problem 98.4% of the time. I'd totally eliminate the carb as a problem before chasing anything else.
Dave2n
12-05-2006 12:17:54
 Re: 1948 John Deere B in reply to Dave 2N, 12-05-2006 12:16:00
HOWEVER---now that I've thought about it, my very first B was a 48 and it WAS the governor. I've probably muddied the waters now. Sorry--but I still say get after that carb before diving into something else.
John T
12-05-2006 10:49:25
Ron, if you hadnt said you replaced the carb, my answer would be I suspect one of the carbs idle circuits is plugged/restricted, but hey even the replacement carb may have the same problem????? If an idle circuit is plugged up at idle the governor keeps bumping her up to the load circuit then it backs off n does the same thing over n overrrrr surging n hunting versus any sweet slow even idle.
Have you tried adjusting the carbs top idle needle????? Does that have any affect????? ? A beginning rough in setting is closed down then back out open around 1.5 to 2 turns out, try that
To see if its a carb or a governor problem, remove the throttle rod on the carbs top n see if you can manually hold her (butterfly) at a slow sweet even idle or if she dies at slow idle cuz the governor cant bump her back open???? Which may mean the carbs idle circuit is plugged up if adjustment dont help.
Other causes of poor idle may be a vacuum leak like at the carb to manifold junction or throttle shaft bushing etc, at idle if you spray WD 40 or carb Cleaner around the carb n manifold etc if she speeds up n smoothes out you found a vacuum leak contributing to poor idle.
Mr. Pat Browning has often posted (do a search) his good method to test for idle and load circuit carb problems, I think he manually throttles her with the load n idle adjuster screws closed down one at a time to see how she performs to indicate which, if any, of the carbs basic circuits is performing or not, something like that. I do it somewhat the same and its NOT rocket science.
Of course, a weak spark and/or timing can affect idle, TRY A NEW SET OF PLUGS MAYBE !!!!!but Id start with the carb tests for now. Also check the points for proper gap, replace if badly burned or pitted, if only gray oxide coated, non abrasively clean/buff/polish them by running a dollar bill or shop cloth between them
LET US KNOW WHAT HAPPENS
John T
