1938 B HELP
flying jd
12-05-2006 05:09:51
I am new to collecting and just bought a 1938 B runs great. I will need you all's help from time to time. I noticed that there is an oil leak coming from under the governor where it bolts to transmission case, gasket or?? I also need to replace the foot rest where the seat bolts down, are replacements available? Any help will be appreciated
Toot
12-06-2006 20:51:45
 Re: 1938 B HELP in reply to flying jd, 12-05-2006 05:09:51
I believe the foot rest is the same on the styled B"s with the pan seat.
Anderson
12-05-2006 08:45:27
Kim Johnson out of Minnesota has alot of used parts for old two cylinders. He would probably have a good used one for you. His number is (218)729-7143.
John T
12-05-2006 06:05:55
jd, Yep theres a big flat wrap around gasket under the governor and yes it can leak. Theres also a gasket on the flywheel side under the big governor shaft end bearing cap which may have more then one shim gasket as its part of how the governor bevel gears are adjusted, I wouldnt mess with any of that unless absolutely necessary and shes leaking bad.. In the event you needed to replace the big bottom gasket under the governor, theres a couple issues, one theres an oil line up underneath up from the crankcase to the governor which is removeable via the big top removeable crankcase cover (behind the governor) and the governor drive gear MUST be timed back to the camshaft gear under it cuz it times the mag out there on the end on the clutch side.
John T
