J.D. model 40 Two-Row Utility
E.
12-04-2006 19:00:49
I purchased the subject tractor recently and the drawbar was missing. What I need is the measurements, length, width and thickness, of the stock drawbar along with the measurements for the hole pattern. Thanks.
E.
12-05-2006 18:15:18
 Re: J.D. model 40 Two-Row Utility in reply to E., 12-04-2006 19:00:49
Thanks Johnnyputt for your efforts. Mike M. is correct---my tractor is a 1955 JD 40 Two-Row utility. 1955 was the first year for this model and there was a limited number produced, I believe around 1500. The two-row utility configuration went on to become the most popular model of the 420 and 430 I think. With the 420 and 430 they were referred to as the Row-Crop Utility.
The drawbar for the JD 40 Two-Row Utility tractor is a long one. It attaches to a bracket that interacts with the mid-tractor implement mounting bracket.
Mike M
12-05-2006 18:57:04
 Re: J.D. model 40 Two-Row Utility in reply to E., 12-05-2006 18:15:18
I got pictures and measurements. I sent an email earlier from this site to you. Answer it and I can send them right to you.
E.
12-05-2006 21:22:41
 Re: J.D. model 40 Two-Row Utility in reply to Mike M, 12-05-2006 18:57:04
Mike M., My e-mail is: [email protected]
I'm looking forward to getting the measurements. Thanks so much.
Johnnyputt
12-05-2006 14:13:25
 Picture of other drawbar in reply to E., 12-04-2006 19:00:49
third party image
I've got a 320U here I could measure for you, but would have to check the book to see if it's the same as a 40U, and it would depend on which 40U you have.
Bruce
Johnnyputt
12-05-2006 14:08:12
third party image
E.
There are two different drawbars for two different serial number ranges as you can see with these pictures. The material to use is cold roll steel. I"m presently making one for a 40V.
Mike M
12-05-2006 15:37:51
 Re: J.D. model 40 Two-Row Utility in reply to Johnnyputt, 12-05-2006 14:08:12
He has (I thought) a two row utility which should be a 40-W
and they are not like those.
Johnnyputt
12-05-2006 17:05:48
 Re: J.D. model 40 Two-Row Utility in reply to Mike M, 12-05-2006 15:37:51
Oops.....I read 'utility' and those pictures are worthless for this model. Sorry.
Mike M
12-05-2006 04:37:18
I got one. I'll see if I can get what you need fairly soon. I'll send an email.
Maybe others can help with what grade of steel to use ?
E.
12-05-2006 11:05:42
 Re: J.D. model 40 Two-Row Utility in reply to Mike M, 12-05-2006 04:37:18
Thanks Mike M. I really appreciate your willingness to take the measurements and send them to me.
E.
