Hydraulic pump on JD 2640?
NHbalerman
12-04-2006 18:56:27
My hydraulic pump went bad on my 2640 and my dealer got me one from A&I and it went out about a week or two and then they gave me another one and now it has gone out,if my 90 day warrantee is out and they want replace this one where should I look at tearing it down?What should I look for? It seems like it just quit pumping and the drive is all good the key wasn't sheared,where should I start? Thanks
NHBalerman
12-06-2006 04:37:47
 Re: Hydraulic pump on JD 2640? in reply to NHbalerman, 12-04-2006 18:56:27
Thanks for the info. Yes we did check the filters,cleaned and changed and they were not dirty and did have a good flow of oil to the front pump,so I guess that something did just brake inside the pump. Dealer called yesterday and they are going to warranty the pump,but next time it will probably be on me but hopefully it does not happen again. Thanks
Glen in TX
12-05-2006 12:24:02
Yeah they don't quit all at once usually with hydraulics slowing gradually or acting erratic. Check the sump screen or the intake pipe to pump or see if someone left brake material stuff in it or a RED rag in it like some bozo wanna be left in our 2510 once!
TylerARK
12-05-2006 05:57:08
Has anyone checked the output of the transmission pump ?? Has the transmission filter been changed? Has the sump screen been checked ? The transmission pump supplies the front pump and if it isnt sending enough oil, it will make the main pump go out.
Take the supply line off the front pump and put a bucket underneath it, either pull the kill cable out or take the wire off the top of your injection pump so the tractor wont start. Crank the engine over and see if there is a nice finger sized oil stream coming out or not. If not, you have problems in the back somewhere.
Hope this helps.
Tyler
Bob
12-04-2006 21:20:48
I ASSUME they checked the rear sump screen for brake debris, and made any repairs that were indicated???
jdemaris
12-04-2006 19:12:00
Something does not sound right. In general, those piston pumps just don't quit - all-of-a-sudden. They often die slow deaths with lots of warning along the way. I find it hard to believe your pump is the problem. Take one that you feel is bad - and pull it apart. There are not that many parts inside - if something crapped out you will see it. I'm not sure if you've got the German piston pump or the US built 2.4 cubic inch pump, but either one is an eight-piston pump.
