Continuing on with JD70 Starting problems
txasylum
12-04-2006 15:20:40
Okay, put new plugs in today. Got the 12v coil that says no resistance in it. Took out my ballast regulator. Timing is good again. Tried to start, nothing. Sprayed starting fluid into the air stack intake. Tried to start over and over again. Only one time did it act like it wanted to start. But nothing else. More ether, nothing. Even put some gas into the cylinders, nothign. Battery is too drained now to turn it over. Got the charger on it now.
Man, what a pain.....
ChadS
12-05-2006 14:30:52
 Re: Continuing on with JD70 Starting problems in reply to txasylum, 12-04-2006 15:20:40
Compression test for sure,,, try filling the cyls up with a mix of gas and marvel mystery oil, let it set overnight,, if the cyls are dry,, that should make it a little more flammable in the cyls to promote an explosion,,, too much either will make the engine hard to turn over,, so be careful how much you put in,,, Sounds like its dry in the cyls,,, Run a compression test,,, they are usually at 95-115 psi at cranking speed,,,, some are higher, some can be lower,,, but if its way low, it wont start.
Glen in TX
12-05-2006 12:33:57
Good compression? That's why 420W telling you to put oil in it to help build compression back up some if needed. Fuel flow to vaporizer? Fuel flow to carb? Valves are working for good compression or something in valve train stuck or broke? Check valves and camshaft. Air flow? and fire ?
Ben.So.Tex.
12-05-2006 10:31:11
Pull the air intake off the front of the carb and see if the dampper/shutter are open. Had a A that some how they shut them self and it would not start.Like to have pull all my hair out.
later Ben
Mike M
12-04-2006 20:07:12
Did you ever have this tractor running ??
If you bought it not running then there maybe alot more wrong than you thought ???
DRL
12-04-2006 16:56:21
Haven't been following your progress, but if you have a LP tractor, here is what my Dad found out with his 620lp. When it didn't want to start, he would either put in new plugs, or take the old ones out and clean/dry them. Seems that the LP doesn't want to ignite if there is a presence of moisture, and his would seem to collect moisture, especially if he was only using it to feed cows, etc. If they aren't ran until they reach operating temp for a good long while, they will collect some moisture in the combustion chamber. When it gets cool/cold, it was a 50/50 crapshoot whether the tractor would start without taking out the plugs and blowing them dry with compressed air. Not sure if this will work for you. Are you 100 percent sure that you are getting spark? And yes, there is a choke on LP tractors. I'm not sure where on the carb it is as he didn't get the 620 until after I moved away. He also had troubles with the electric fuel shutoff as it sometimes would not open, or try to close while running. It looks kind of like a sediment bowl on a gasoline tractor with a metal bowl. He would take a wooden hammer handle and tap on it a few times and it would eventually open up. Don't use anything that would create a spark. If there are any leaks, you may go up in a blaze of glory. Don't know if any of this will help, but something to think about. Good luck.
txasylum
12-04-2006 17:50:44
 Re: Continuing on with JD70 Starting problems in reply to DRL, 12-04-2006 16:56:21
I will try cleaning the plugs again tomorrow. Just put new ones in today, and went back to the 6v with a ballast.
No one around here with another tractor to tow me.
Hoping the cool weather is the culprit.
JDD
12-04-2006 16:28:17
My fathers 70 has a low oil pressure shutoff and if it sits for a while, the pressure is too low to start so, you have to press down on the top of it (the button down) and hit the starter then she runs.
txasylum
12-04-2006 17:52:34
 Re: Continuing on with JD70 Starting problems in reply to JDD, 12-04-2006 16:28:17
Low oil pressure button? Not sure where that is. Is it on the dash or somewhere else?
snake2
12-04-2006 16:18:20
i had same problem, changed mine to 24 volts starts like new one now. that was several years ago and have had no problems.
buickanddeere
12-04-2006 17:03:21
 Re: Continuing on with JD70 Starting problems in reply to snake2, 12-04-2006 16:18:20
You converted a gasoline, all fuel or LP 70 to 24V start?
430WLPG
12-04-2006 15:56:25
I don;t think a choke will help you any ,But If it ever had one it is on the top between the barrels,is just a brass shaft with some linkage sticking towards to back or if it's a early 70 it won't have one just a slotted plug I have a early without and a late with. Did you set the plugs on .015? What about squirting oil in the cylinders?
txasylum
12-04-2006 17:54:48
 Re: Continuing on with JD70 Starting problems in reply to 430WLPG, 12-04-2006 15:56:25
I dont' see any thing on the carb for a choke, so I guess I never had one.
I did put plugs at .015. I squirted (two squirts) of oil in the cylinders yesterday with the old plugs. Should I do that again?
Bob
430WLPG
12-04-2006 18:31:18
 Re: Continuing on with JD70 Starting problems in reply to txasylum, 12-04-2006 17:54:48
Yes,I would put at least 10 squirts of oil in the cylinders, thats a big cylinder two won't hardly wet the bottom. You don't have a fuel shut off button that's on a gasoline. The choke thing is about a 1" foward from where the carb bolts to the intake kinda like looking down the barrel of a double barrel shotgun there's a raised casting and yours probably has a slotted plug in the hole. Did you try turning the fuel off at the tank and then start cranking or turn off fuel and let it sat for a hour or so then crank it (without pushing button on the converter).They can flood easily on Lp
txasylum
12-04-2006 18:42:22
 Re: Continuing on with JD70 Starting problems in reply to 430WLPG, 12-04-2006 18:31:18
Oh, and after I put the oil in the cylinders, what then? Should I take the plugs out and turn it over to blow it out, or try to start the tractor with the oil in there?
430WLPG
12-04-2006 18:52:48
 Re: Continuing on with JD70 Starting problems in reply to txasylum, 12-04-2006 18:42:22
Try to start with the oil in there the compression will force it into the rings sealing them for more compression.
txasylum
12-04-2006 19:15:43
 Re: Continuing on with JD70 Starting problems in reply to 430WLPG, 12-04-2006 18:52:48
I just put ten squirts of oil in each. I put my old plugs in and turned the engine over a few times. I then took the old plugs and put my good ones back in. I will try to start again tomorrow.
Bob
430WLPG
12-04-2006 19:26:08
 Re: Continuing on with JD70 Starting problems in reply to txasylum, 12-04-2006 19:15:43
Sounds like a good plan, Good Luck Let us know what happens. OT My cousin overhauled a Chevy 305 and couldn't get it to start, He was on his 2nd starter and battery, he had cranked it half way around the world. So he finally called and said can you help. So I went checked his timing and firing order was all good, I told him that the only thing else to do was to put some oil in the cylinders and try it,it turned over 4 or 5 times and started right up, He had the most dumbfoundedest look on his face I've seen in a long time
txasylum
12-04-2006 19:41:17
 Re: Continuing on with JD70 Starting problems in reply to 430WLPG , 12-04-2006 19:26:08
I hope it is that easy. I think I have cranked this thing at least 1/4 of the way around the world.
I have restored/rebuilt a bunch of old VWs. I can tell you everything about those. But this is my second tractor. My first was a MF-35. Very easy compared to this JD. This sucker is giving me a tough time.
I probably will stick my truck battery on there in line with the other battery for that extra voltage. Hope it starts.
Thanks
Bob
txasylum
12-04-2006 18:39:01
Should I put the oil in the cylinders now and try cranking tomorrow evening or should I put oil in before I crank it over?
As for turning fuel on and cranking. I have cranked this thing over many times, so I really can't remember when I have had the fuel on. Of course I turn the fuel off every night, so the next day when I start I turn the fuel on and hit the primer button.
Bob
e johnson
12-04-2006 15:42:21
 very frustration in reply to txasylum, 12-04-2006 15:20:40
My experience with two cylinder jd's has been that when everything is connected and assembled correctly they start on the first or second compression stroke, no sense in beating up your starter and battery. When you get it right you'll know as soon as you hit the starter. good luck to you....we have all been there.
txasylum
12-04-2006 15:24:42
Oh, there is no choke on the tractor. I can see on the dash where there used to be a choke, but I can not locate the connection point on the carb. Is there suppose to be a choke on this LPG tractor? If so, where the heck does it go? The only thing on the carb is the throttle linkage and the two idle adjustments. Nothing else.
bob
txasylum
12-04-2006 18:23:50
 Re: Continuing on with JD70 Starting problems in reply to txasylum, 12-04-2006 15:24:42
I'm about to give up on this thing. It might sit through the winter before I can mess around with it. I'm getting fed up and don't feel like messing anymore. But, I probably will continue, which means I will probably will be asking more questions here.
