1967 4020 generator problems
GLEN J
12-04-2006 06:56:42
I have a 1967 JD 4020. It has (2) 12volt batteries. If I use the tractor with the lights on for any amount of time the next day it will not start (starter clicks). If I do not use the lights, it starts every time without hesitation. It appears that the generator is not charging fast enough. How do I test if this is the problem.
Any other Ideas?
Generator was replaced two years ago along with batteries any all cables.
Glen J
Lee B
12-04-2006 20:16:56
 Re: 1967 4020 generator problems in reply to GLEN J, 12-04-2006 06:56:42
"If I do not use the lights, it starts every time without hesitation." - It only appears to be so, in fact half of the system is NOT charging at all. You can tell this by looking for brush sparking (you may need a mirror to see it clearly) at a decent idle in the generator itself, no micro sparks at the brush/commutator interface means you are not charging with the upper half of your 24 volt generator, only the bottom half of the 24 volt generator is charging. Try a new regulator if this is the case.
A new regulator was the fix here for the same symptoms you describe. Be careful to follow exact JD 4020 24 volt polarization proceedures or expect to purchase additional regulators.
The generator looks like a regular 12 volt - it isn't. The regulator looks like a regular 12 volt - it isn't. The starter looks like a regular 12 volt - it isn't either. Don't change any item without changing all of them AND rewiring the entire tractor - my advice is to fix what you have and leave the 12 volt alternator conversions for easier to understand projects. I'm a whizz at this stuff - I don't understand the JD 4020 24 volt split system and I say so without apologies, but I do know what to look for when one doesn't work.
Gerald J.
12-05-2006 09:27:33
 Re: 1967 4020 generator problems in reply to Lee B, 12-04-2006 20:16:56
You certainly do not understand the 4020 24 volt generator and starter. The battery and the lights have a ground, but the generator has only ONE circuit, no grounds, its 24 volts floating. There is NO top or bottom half. Its all one. And that is also true for the starter until ground up brush adds an unwanted ground. The center of the battery is ground so there are two 12 volt systems for lights and other electrical loads. Unbalance in those loads can cause one battery to be charged less than the other because of the loads diverting charging current.
Poor charging is inherent in the design with only a 240 watt generator, its clear that they expected it to be run 6 or 8 hours for each start in the daytime and longer with the lights on.
A regulator can make that charging worse, did for my gas 4020.
The 24 volt Deere system isn't a whole lot different from the 120/240 volt system Tom Edison used long ago excepts it is at 1/10th the voltage and the generator hasn't a center tap. That's left to the battery.
Gerald J.
Gerald J.
12-04-2006 09:01:23
The 24 volt generator on the diesel was only rated at 10 amps. Lights can draw that much, but more likely the generator isn't charging that well. I know my gas 4020 generator wasn't. Then I put on an ammeter and the pointer swung from peg to peg as the regulator was sticky. I put on an alternator for not much more than the price of a voltage regulator, now I get years of battery life instead of a year and with the ammeter I can tell the battery is charged in a few minutes rather than the day the original wimpy generator took.
The generator doesn't have the output to charge the diesel in short bursts of running. It won't keep up, adding the lights makes it worse. Its not a good design for a utility tractor, but may be OK if you run the tractor 12 hours per start.
Gerald J.
jdemaris
12-04-2006 14:31:08
 Re: 1967 4020 generator problems in reply to Gerald J., 12-04-2006 09:01:23
The 24 volt system is inadequate - but it's no worse than the 12 volt system in output. It's the balance problem that's the issue. The 24 volt generator has the same output as the 12 volt. When the voltage is doubled, the amperage is cut in half - for the same output wattage. 12 volt generator peak output is 20 amps at 14 volts, and the 24 volt generator is 10 amps at 28.5 volts. Both are equal - 280 watts versus 285 watts. When running lights on a 4020 - if a 12 volt system, if you run two lights - it makes no difference if the system is 12 volts or 24 volts. If running one light though, the 24 volt system has a problem - being out of balance. Deere Co., at the time when the system was current, told us to use a ballast resistor when one light is used - which is kind of a waste. Either way, either system - if the tractor is running at an adequate RPM (not idling or just above), can handle two headlights with two 80 watt bulbs with no problem if things are working correctly - and will still have enough to charge the batteries at a slow 5 amp/12 volt or a 2.5 amp/24 volt rate. Most of the 3020s or 4020s we sold and serviced - in the real world - always had problems -due to many reasons. Updating to 24 volt alternators in place of the generators made them charge much better at lower engine speeds - but did not fix all the other problems.
jddriver
12-04-2006 07:51:50
In addition to what Glen said make sure that the load is balanced on both batteries
Glen in TX
12-04-2006 07:35:29
See if you have 12 - 14.5 or 24 - 28 volts if a 24V system on battery terminals with a voltmeter indicating enough charging. If not check wiring, regulator, grounds, terminals, cables or pull generator and have it bench tested. Test batteries also to see if one is bad pulling other one down. If it's still a working tractor I'd convert it to a alternator even if 12 or 24. Electric rebuild shops will have alternators and JD will have rebuilt alternators or generators also.
GLEN J
12-04-2006 12:12:28
 Re: 1967 4020 generator problems in reply to Glen in TX, 12-04-2006 07:35:29
WHERE IS THE BEST PLACE TO DO THE TESTING?
SHOULD I HAVE THE TRACTOR RUNNING FAST OR AT AN IDLE?
THIS IS MY CHORE AND LOADER TRACTOR. IT GETS STARTED EVER DAY WHEN WE ARE MAKING HAY AND 2-3 TIMES A WEEK IN THE WINTER.
ANY IDEA OF COST TO SWITCH THE WHOLE SYSTEM OVER TO 12V AND ALTERNATOR?
I ALSO HAVE 1969 4020 THAT HAS ALTERNATOR SET UP.
Gerald J.
12-04-2006 15:08:10
 Re: 1967 4020 generator problems in reply to GLEN J, 12-04-2006 12:12:28
Last I saw a price Deere wanted about $600 for the kit. The big part is the Nippendenso heavy duty 12 volt starter. The alternator need not be very special except for the 5/8th inch wide pulley, that cost me $12 at my local auto electric shop. Wiring changes can be fairly simple, just leaves the complications of two switch poles for lights still in service. Might lead to a fuel gauge problem if it was on the negative side and gets moved to positive with negative ground to take a standard alternator.
Deere DID change to 12 volt with an alternator for air conditioned caps even on the early 4020 and eventually for all diesel 4020. And the 12 volt system gets away from the battery load balance problems and the weak charging system.
Gerald J.
Glen in TX
12-04-2006 13:25:10
So yours is still 24V now I assume. Depending on how your cables are hooked should still be able to test on ground and input to starter for 24-28V output at open throttle. Less on idle. Does it still have original switches and starter too? Like others said it won"t charge enough with that generator for short periods of time just for a short time chore tractor. If that"s what you want leaving it original you"re going to need to plug in a block heater and trickle battery chargers for it too. Most local electric shops can help you convert it and have probably already done several in your area also.
GLEN J
12-04-2006 14:37:40
 Re: 1967 4020 generator problems in reply to Glen in TX, 12-04-2006 13:25:10
It does still have original switches. I did add extra light and flashers on back. Traffic is starting to get very heavy in my area. I think I had $600-700 into last time I went through this. With new batteries, cable and generator.
Thanks for the help
Glen J
msb
12-04-2006 14:03:13
If you are not interested in keeping the tractor original, spend the bucks and convert it over to a 12 volt alternator and starter.You will love it.No more balancing the electrical load, batteries will always be charged up and will be easy to jump start if they somehow get run down.Also only takes one battery charger to do the job.
