unstyled A Manifold
Danes Dad
12-03-2006 16:37:34
Can someone tell me the differece between an all fuel manifold and a gasoline one? How can I tell the diffrence when looking at them? What part no. would fit on a 36 A.
Glen in TX
12-04-2006 07:52:19
 JOHNSON Repo Gas Manifold in reply to Danes Dad, 12-03-2006 16:37:34
There is a aftermarket reproduction manifold available that replaces the A36R that fits A up to 487999 and it's a repo of the Johnson cold gas manifold. It has the same square exhaust flange. Any of us aftermarket vendors could sell you one and they may show it listed on here too. Did you check?
adsma
12-04-2006 04:47:54
 Re: unstyled A Manifold in reply to Danes Dad, 12-03-2006 16:37:34
The original all fuel manifold for a unstyled A is A36R and for all unstyled A"s there was not a cold gas manifold offered from deere unless you have a AR/AO which carry the castings numbers A1003R, A2690R, or AA5578R.
Duane Larson
12-03-2006 20:06:44
Danes Dad,
In general, gas manifolds had less material than all fuel manifolds - the extra mass in the AF manifold was needed to heat the fuel going into the head to make it easier to gasify.
Johnson Machine Shop made a gas manifold for an unstyled A - part number A-20. These occasionally show up at swap meets, or you might try advertising in one of the magazines. They were sold thru Tractor Supply and Central Tractor.
Heisler also made a high compression head and associated manifold for the unstyled A - the head was HA-587 and the manifold for that head was HA-1362. Heisler also made a HA-362 gas manifold for the A587R Deere unstyled head. Heisler products also show up, but are valued by pullers and the prices can be high.
Glen in TX
12-04-2006 08:35:05
 Re: unstyled A Manifold in reply to Duane Larson, 12-03-2006 20:06:44
Hi Duane, The Johnson manifold is available repo aftermarket again unless they ran out again?
Duane Larson
12-04-2006 16:07:46
 Re: unstyled A Manifold in reply to Glen in TX, 12-04-2006 08:35:05
Hi Glen,
A big oops - I knew that but forgot when responding. Don Dufner had the old Johnson patterns at one time and had a bunch cast - I wonder who is casting them now?
Glen in TX
12-04-2006 16:43:11
 Re: unstyled A Manifold in reply to Duane Larson, 12-04-2006 16:07:46
I don't know who is casting them but some of those gas manifolds been available here from YT and most other aftermarket vendors too for the last 2 or 3 years now.
430WLPG
12-03-2006 19:38:03
I never saw a gas manifold for a unstyled A, The later A gas manifolds won't fit because the ports are shaped different, the intake especially. I tried to put one from a 41-46 A on a 37 A wouldn't work easily I guess anything is possible for enough MONEY. I have it still it NOS and I would sell it if you want to try.
Dave in SV
12-04-2006 03:27:12
 Re: unstyled A Manifold in reply to 430WLPG , 12-03-2006 19:38:03
I might be interested in your NOS gas manifold...if it fits my serial number 634007...?
