1942 B camshaft timing
Mike w J
12-03-2006 15:44:52
The 3 bolts that hold the gear to the shaft broke and fell out. The tin bolt keeper broke and let the bolts 2 fall out. The 3rd got tired and broke off. I put it back together and thought I had it timed right. What I thought was a timing mark on the crank must not of been.When I crank it the LH impulse mark is about 1 1/2 in. past the mark when it fires it will run but starts hard. Can I turn the cam gear a cog or 2 ? I started put it together about 6 months ago but just got around to finishing it.THANKS
Mike M
12-04-2006 05:25:17
 Re: 1942 B camshaft timing in reply to Mike w J, 12-03-2006 15:44:52
Do you have the index marks on the camshaft and it's gear indexed ? I think they are V's on the inside edge at the small part where the tapered splines are. Then on the outer rim of the cam gear on the inside edge you should have another V or * (dot)that needs to match up to the same type of mark on the inside edge of the crank gear. This mark is hard to see if I remember correctly as it is kinda near the throw of the crank. And the crank is not at TDC position when you find it. Then after all that you should be able to bring the fylwheel up on LH exh. open mark and all the clearance .022 cold should be gone on that valve when those marks line up. Then get mag. to fire at TDC on LH compression and it should go.
jd b puller
12-03-2006 20:04:51
Mike, like John said, you've got to get EVERYTHING right or it won't work. We could try to figure out which one is right (I THINK Intake centerline is 112*), so if you found TDC of the piston and had some sort of degree wheel you could find it. Personally, I'd pull the crankcase cover and get a flashlight, some acetone, a cottonball, and your wife's fingernail polish (use one that's about empty, she won't want it back).
Find the timing mark on the crank and clean it with the cottonball and acetone (fingernail polish remover). Let it dry and mark it with the fingernail polish. Do the same on the cam gear and the governor gear. If you can't find them, try harder.
If you still can't find them, you'll have to do the degree wheel thing. If you don't have a degree wheel, call Dominos and order a large pizza and some Budwieser. After you scarf down the Pizza, (don't dring too many Buds) you've got the material for your degree wheel. Just use a protractor, compass and some triangles and you can get it close enough. duct tape it to the flywheel once you find TDC of the piston and trial and error the Intake C/L until it's 112*. Once that's right, at least you know the cam/crank is right. Then go to the gov. You know it should fire on impulse at TDC. Adjust as necessary -- Hopefully you can find your marks.
When you are finished, finish the Bud.
Good luck.
John T
12-03-2006 18:02:44
Mike, does that flywheel (in addition to left hand Impulse) also have the Left Hand Exhaust timing mark????? ? If it does when its at the 3 o clock position in line with that flat mark on tractors side, the cam gear should be timed such that the left hand exhaust valve is just beginning to break open I believe.
If the cam gear is off time it drives the governor gear you know (so if its off ignition timing is also) and if the flywheel is on the correct spline and the cam n crank are timed correct and also the cam to governor gears are in time..... ... When the flywheels left hand impulse timing mark is at 3 o clock the left piston ought to be at TDC,,,,,the open slot in the flywheel ought to be fore n aft horizontal,,,,, the female drive slot in the end of the governor shaft (where mag mates into) also ought to be flat horizontal fore n aft.
Im not sure if its just the governior gear is off time with the cam gear or the cam is off time to the crank as EITHER affects ignition timing, buttttt tt you gotta get er all as I described above and get her to where she fires TDC when the LHI mark is at 3 o clock and if the cam to governor did NOT get changed (but likely did if cam gear was loose) then it may just be a matter of changing the cam gear to where it has the ignition in time but it sounds like the valve/cam timing may be off to the crank which also made the ignition off
This isnt my best area so take this with a grian of salt
John T
Mike w J
12-03-2006 19:35:47
 Re: 1942 B camshaft timing in reply to John T, 12-03-2006 18:02:44
Yes it has the LH exhaust mark also .When I timed the gears They had a round circle on the sides of the gears but they were both on the teeth so I think I could be 1 cog off is that what they used for marks?
John T
12-04-2006 07:16:40
 Re: 1942 B camshaft timing in reply to Mike w J, 12-03-2006 19:35:47
Mike, Sorry Im just not very smart concerning the gear timing marks, buttttt t from reading Mikes post looks like its a pretty sure thing now (he agreed with me) you gotta time the cam to crank so when the flywheels Left Hand Exhaust is at 3 o clock the left cylinders exhaust valve ought to just begin to open. Ima thinking maybe youre just one tooth off that now so read what Mike n the others said and try n retime the cam to crank and hopefully (IFFFFF F cam to governor timing is still correct, see mt first post to tell how) you will be okay,
LET US ALL KNOW
John T
