E johnson, My primary tractor for my part time farm is a 5520 cab model. Yes, they are more money, but I need to defend the other comments. It has the guts for everything I do including a 14' IH Vibrashank, 16' Brillion pick up drag, 4-16 semi attached JD plow, brillion 7 shank chisel, 430 now 447 round baler, 9 ft disc mower. My farm is very hilly. You can make it weigh what ever you want it to weigh. Mine is on 18.4 30 / 12.4 24 tires set wider for hay and loaded with rim gard plus wheel weights and a 275 lb. front starter wieght. I only know of spinning out with the loader digging dirt and it has the power to do so. I do not recall spinning or powering out in any reasonable field speed for the job at hand. I do have to downshift on the road hills with two loads of hay (22 bales @700 lbs ea.)and the loader. If you get anywhere near 20K you might take another look at a 5410/5510 or early 5420/5520. It would likely have sync gearing and possibly a reverser. Also you would likely get at least 3 and possibly 5 SCVs. They may be in your range particularly with 2wd, no cab, and no loader. another point of view, Mark
