2510 fuel injector problem
bernie in virgi
12-03-2006 14:10:42
I need to replace the rubber "T" connection going into one of the fuel injectors. Anything unusual I need to know to do this?
J Schwiebert
12-03-2006 16:22:24
 Re: 2510 fuel injector problem in reply to bernie in virginia, 12-03-2006 14:10:42
Replace them all while you are at it. I also have a couple sets of Corbin Snap ring pliars which make the job easier. We have all 6 cylinder Deere's so they may be easier or harder.
Bob
12-03-2006 14:33:22
Assure that all ladies and boys too young for cuss words are out of earshot before attempting this project.
Seriously, once you get adept at working with the spring wire hose clamps, the job isn't too bad. I suggest buying the whole set of plastic "T's", 'cause if one is cracked and leaking, one or more of the others will crack or break while you're jockeying the return lines around.
