First of all, what do you mean by "jd auxiliary valve"... the loader valve you've added? The control valve at the front of the front pump? Or, and "OEM" valve for a second remote??? It's good you are returning the oil to the "charge circuit" through the filter cover.
That eliminates one source of the front pump getting short of oil and chattering. Have you changed the filter, and cleaned the sump screen? Does the "chattering" stop if you "feather" the control lever back a little, reducing hydraulic flow and pump demand a bit? If so, the open, unrestricted flow of oil through the added control valve MAY be exceeding the capacity of the front hydraulic pump. The OEM hydraulic valves under the hood have a flow adjusting screw, locked with a locknut. It's function is similar the the "rabbit-turtle" control on the SCV'c on the newer tractors. Your added valve has NO such flow control, and, when the lever is moved fully, allows full-flow. I have a 4020, and have the flow control on the OEM valve set too far open on the valve for the loader lift, and, if I move the lever all the way, the system "chatters" like your's does. I'm sure if I backed the flow ajustment off a little, the chattering would stop. It's POSSIBLE my pump or your's may have a bad valve ADDING to the chattering, or we may simply be asking too much of the pump (flow-wise). I have heard of guys putting an adjustable valve ahead of the added valve or even a fixed flow restrictor. Having the front pump checked with a FloRater will tell if the pump is delivering what it's supposed to, or if it DOES have a problem with one or more of it's 16 valves and 8 pistons, reducing flow and causing pulsations under high-demand conditions.
