48-A Steering Gear Oil?
Sam S.
12-03-2006 11:25:05
Currently the Steering Gearbox has a substance looking similar to bad grease. What is supposed to be in there and how much?
Thanks,
Sam
adsma
12-04-2006 05:01:43
 Re: 48-A Steering Gear Oil? in reply to Sam S., 12-03-2006 11:25:05
The reason that people say to use cornhead grease is that when it is in motion it flows like gear lube, but when it is not moving is stays in place like grease and doesn't leak out like gear lube will. The JD part # is AN102562 and should be available at any JD dealer espcially those in the corn growing regions of this country.
Maark
12-03-2006 13:39:22
Cornhead grease is available from your JD dealer. It comes in a tube for your grease gun..
Glen in TX
12-03-2006 12:34:25
Someone may have mixed grease and oil or put some corn head grease in it. Originally recommended was hypoid gear oil in box up to lower edge of steering gear. Too full and it will run down the shaft and out bottom of pedestal. The corn head grease works well or mix you own with grease and oil or use gear/trans oil. Probably need to clean it out and check for wear or adjust while there anyway.
Sam S.
12-03-2006 13:00:27
 Re: 48-A Steering Gear Oil? in reply to Glen in TX, 12-03-2006 12:34:25
Thanks Glen.
Can I get that Corn Head grease at a JD Dealer?
Glen in TX
12-03-2006 19:41:15
 Re: 48-A Steering Gear Oil? in reply to Sam S., 12-03-2006 13:00:27
Yes, Cotton picker grease or even JD multi-luber grease will be about the same and work also.
