70gas governer blow up
StuBC
12-03-2006 07:00:14
Hi guys,
My governor drive gear has packed it in (not the fan drive bevel pinion gear). Quite a dynamite, its hollowed right out in the inside from the smashing, and the gear itself is broken. So I guess I look for a new one. This one has some weld on it, so its been messed with before. I think I can handle this re and re. We will see.
Two questions,
1) Lots of metal shards and pieces. Whats the best cleanup process? This is linked to the main crankcase? I can hand pick and magnet out some but the system should also be contaminated. Dump engine oil and anything else?
2) What would make this piece destroy itself. The bearing does seem good that keeps the shaft in line. I do use the hydraulics.
Thanks for your earlier advice Frank (FIT), helped a lot. But I guess I have lost time now that the gears hae lost mess
Stu
RalphinWI
12-04-2006 10:27:45
 Re: 70gas governer blow up in reply to StuBC, 12-03-2006 07:00:14
I can't tell from the photo whether the second gov weight is still attached or not. If not then I would guess that is the initial source of the trouble. In my case, an A pitched a weight, bent the attaching pin by about 45 degrees and then was used for some time. Couldn't run at more tha 1/2 trottle without excessive overspeed. After use and a long ride on a trailer the weight was still laying on top of the main case. I'm guessing the cotter pin on the gov weight pin finally wore through.
F-I-T
12-03-2006 17:00:30
Drain the oil, rinse it with a pump sprayer or an air powered suction mister, probe around with a stick magnet, use a new filter. Big stuff is easy for the screen and filter to catch, and since it is a full-flow filtration system, every ounce of oil gets filtered before it goes to the engine, so I would not be too concerned as long as you wash it down well.
Hard to say, but there is a fair amount of stress on that gear as it powers the Powr-trol pump as well as the fan and distributor. BUT, if it has welding on it, all bets are off. You are talking about the flywheel side, gear driven from the camshaft, right?
>>But I guess I have lost time now that the gears have lost mesh...
Yes, but getting the timing back is a simple matter on a two cylinder JD, so I'd say that that is probaly the least of your troubles. Be sure to examine the camshaft gear by looking down and to the left inside, while rolling the crank, just in case some gear debris fell into that gearset with the crankshaft. Hoping you didn' have any damage down in there.
Frank
Kent Petersen
12-10-2006 18:49:56
 Re: 70gas governer blow up in reply to F-I-T, 12-03-2006 17:00:30
Frank the oiling is full flow but not all. the rockers are fed out of the top of oil pump not filtered also pt pump is driven by idler gear that is driver by cam gear not gov gear Kent
StuBC
12-04-2006 06:35:48
Yes, its the flywheel side gear. Hooks to the Powertrol at the end of the shaft. Has a bearing beside it in the cover.
I will shoot some photos of the welding when my camera charges.
StuBC
12-04-2006 07:57:32
 photo in reply to StuBC, 12-04-2006 06:35:48
third party image
Here is a photo
StuBC
12-03-2006 13:13:10
That last sentence was supposed to say "But I guess I have lost timing now that the gears have lost mesh."
Got ahead of myself typing.
