Freeze plug on JD (B) Transmission?
Harold Reasons
12-03-2006 06:05:02
I have a slight oil leak on the bottom of my '50 John Deere B Transmission. It is coming out of what looks like a freeze plug. Can anybody tell me what this is and what it is used for? Thanks
Mike M
12-03-2006 16:32:18
 Re: Freeze plug on JD (B) Transmission? in reply to Harold Reasons, 12-03-2006 06:05:02
For some reason I think mine has a pipe plug under that pto shifter ? maybe there is a serial number break ? or someone put the wrong thing in there ???? The parts book should show this if you have one handy as they are very accurate detail.
F-I-T
12-03-2006 15:24:59
I'm puzzled. I have never seen a Welch plug or a freeze plug in the bottom of the main case of a late "B", and the parts book does not show one located there either. Are you sure it's not a flat, four-point recessed, pipe plug? Where, exactly, is it located?
Frank
jdjerry
12-03-2006 16:26:26
 Re: Freeze plug on JD (B) Transmission? in reply to F-I-T, 12-03-2006 15:24:59
My 48 B has a welch plug on the bottom of the case and if I remember right it is on the bottom of the pto shifter. It has been a while since I worked on it but I had it out because it was dripping oil.
F-I-T
12-03-2006 16:48:55
 Re: Freeze plug on JD (B) Transmission? in reply to jdjerry, 12-03-2006 16:26:26
third party image
Yes, now I do recall that there is a plug under that pto level through hole. I was picturing one more in the centerline of the case.
Here's a picture. The illustration looks like a pipe plug, but it is described as an expansion plug. The unstyled "B" book calls out a pipe plug in that hole, and even specigfically calls it a "Pipe Plug, in Power Shaft shifter hole".
Glen in TX
12-03-2006 21:28:48
 Re: Freeze plug on JD (B) Transmission? in reply to F-I-T, 12-03-2006 16:48:55
Maybe it doesn't even have a PTO shaft and someone goobered a freeze plug in the back casting shaft hole ??
Glen in TX
12-03-2006 10:16:36
Harold, The common trade name for those convex plugs was a "Welch" plug and not a freeze plug. Most if not all should be available from JD yet. If not check with a local small auto supply / engine machine shop or if you know the hole size give me a holler as I stock many sizes of those plugs. Sometimes you have to measure the hole in 32ths or 64ths to get correct size so don't guess at it with a plug that fits loose or it will leak. Just put a tad bit of permatex or gasket sealer around plug edge before you punch the center to expand it when installing a new one.
P Browning
12-03-2006 06:16:39
Harold -- You will find what appears to be a freeze plug on many a tractor out there. If you were to look behind the plug you would probably see a machining of some kind for a stationary shaft such as the countershaft in a transmission. And that hole was needed for initial manufacturer's tooling to go into the casting to precisely bore the hole that the shaft was to fit into. Then, as the process was done, insertion of the plug was simple and low in cost. (PatB)
Harold Reasons
12-03-2006 06:45:29
 Re: Freeze plug on JD (B) Transmission? in reply to P Browning, 12-03-2006 06:16:39
Thanks for the fast reply...
