4455 axle seal
HDS
12-02-2006 20:58:30
Wondered if anyone knows whats involved in changing one of the rear axle seals? Started slobering grease now is leaking fluid. Has ring and pinion type axle. Thanks
Glen in TX
12-02-2006 21:42:53
 Re: 4455 axle seal in reply to HDS, 12-02-2006 20:58:30
Axle housing has to be pulled off to replace inner seal. Outer seal is just dust shield for outer bearing.
bubs
12-03-2006 05:55:18
 Re: 4455 axle seal in reply to Glen in TX, 12-02-2006 21:42:53
Do the 8000 series tractors use similar bearings and seals as the 40 and 50 series tractors . And do you jack them up in the same manner to check them?
G/MAN
12-03-2006 13:15:33
 Re: 4455 axle seal in reply to bubs, 12-03-2006 05:55:18
No, 8000-series tractors have the outer bearings oiled by trans/hydraulic oil. Much better system than a greasable bearing that usually doesn't get greased. And technically you CAN check axle play by jacking them up, but we've been told by Deere that with all the wheel equipment on the axle - particularly if there are duals and/or big wheel weights - that the axle can actually bend or deflect enough to show vertical play when there isn't really any there. That's why even on the older tractors with the greaseable bearing, we don't suggest rebuilding the finals until the play is at or above the maximum spec, because it can be very hard to tell exactly what's moving. And of course with wheel inner wheel weights it can be impossible to even get to the axle to measure play. We've got 8000s with 8000+ hours that have never had so much as one final-drive problem. The only common issue is that the earlier tractors used grade 10.9 final-drive bolts that can stretch and allow the final-drive to shift enough that it will start leaking oil where it meets the differential case. Those bolts should all be removed and replaced with 12.9 harware torqued to the proper specs. If caught before a leak develops, you can just go around the pattern and replace them. If it's already leaking the final needs to be pulled and new sealant applied on BOTH sides of the ring gear.
