BG: Make sure you have high enough voltage to the coils. If you have replaced the old coils with the $50-55 each, plastic covered ones, which is what most all of us use these days, those coils run really well for me with no voltage dropping resistor inline, that is run on straight battery voltage. I had a pony that would miss, spit, and backfire as you reduced the voltage, but if you just clipped a lead from the starter cable terminal to the input lug of the distributor, everything smoothed out and the rpm's climbed as required. Since the plug wires are pretty simple get right, (you just take the ones out of the left side of the distributor and hook them to either dash-side plug, and the right side wires go to the right, or front-of-the-tractor plugs), about all that is left is basic timing, float adjustment, and clean out the idle bar tube, but I bet if you hook some higher voltage to that pony, you will be amazed. Also look for ice in the aircleaner if that could be possible given your climate. Frank
