Ignition Switch on JD70
txasylum
12-02-2006 16:48:30
In an effort to get this JD70 started, I have had to replace the ignition system (points, condenser, coil, ballast), buy a new battery, rebuild the vaporizer/regulator (LPG), put new battery wires on the tractor, and more. Well, I thought I had it all done today. I had the timing set and was getting a spark. I was cranking it over and getting puffs of blue smoke out of the muffler. It never started, and the smoke did not continue. So I decided to check the spark again. Now I am not getting a spark. I used my multimeter and checked for voltage on the coil. Nothing.
I dont' have a fuse in the tractor. It was bypassed previously. As I flip the ignition switch on and through its locks (light, ignition, etc.,), my meter will jump but then go back to zero.
Is it possible that ignition switch all of a sudden went bad? I did a search on the Internet and in catalogs for ignition switch, but I am not finding anything. Am I calling this switch on the the dash panel wrong? If so, what is that switch called so I can order another if this is the problem.
Thanks
Bob
txasylum
12-03-2006 15:08:53
 Re: Ignition Switch on JD70 in reply to txasylum, 12-02-2006 16:48:30
To follow up.
I pulled the switch out and tested it at the ign terminal, good reading. Went down to the ballast, getting reading there. So concentrated on the coil/points area. I took all wiring off, cleaned things up, and now I am getting about 6 volts on the negative side of the coil. So I was able to set the timing.
now I am trying to start again. I am getting blue puffs of smoke out of the exhaust, but not firing over yet. Any ideas? Oil in oil bath is good and at appropriate level. Fuel is on. Can't think of anything else to do.
Bob
430WLPG
12-03-2006 07:44:43
One thing you can try before you buy a switch is just turn the switch as far as it will go back and forth several times that will clean the contacts some. And there are 3 positions that the tractor will run two are with the lights on.Just something to try.
txasylum
12-03-2006 07:48:15
 Re: Ignition Switch on JD70 in reply to 430WLPG, 12-03-2006 07:44:43
I thought of that too. I turned it on and off through all the positions several times. No reading on any of those positions.
Thanks
55 50
12-02-2006 19:34:34
I think you are on the right track. Those switches do go bad. They were still available from John Deere in 2003 as I replaced one in a 70 gas for a friend then at a cost $47.77 so I suppose $60 or so now if still available.
John T
12-02-2006 19:29:40
Bob, Those ignition switches have been known to go bad, if a voltmeter or test lamp is placed on its IGN output terminal it ought to glow and read near battery voltage when on and the ignition points are closed, does yours??? If not try to hot wire battery voltage to the high input (from switch, not to coil) side of the ballast resistor n see if theres coil voltage then with the ignition points closed. (It still has to get through the ballast, see next para)
The next culprit may be the ballast resistor has goen bad/open where even if a hot wire or a good ignition switch was putting voltage to the ballast input (from switch not to coil) there wouldnt be any voltage to the coil or the output (to coil) side of the ballast. If all is good and the ignition switch is good and the points are good and closed, there should be near battery voltage getting to the input side of the ballast with around 6 volts on its output side (it drops 12 volts down to 6) and the coils input..... ..... If all the wires are removed from the ballast it should measure around 1.5 to 1.85 ohms, if its an open circuit its baddddd d.
NOTE if you use that in line series ballast (after ignition but before coil) resistor your coil needs to be a 6 volt coil you know, is it???
NOTE I think we discussed this tractor before, it may have the ballast by pass circuit consisting of a wire up from the startrer switch to either the output side of the ballast or the coils input (same point electrically) and if it does its supposed to supply unballasted voltage direct to the coil (via wire from starter switch) but ONLY while shes being cranked. If thats the case and if the ignition is on, even if the ballast were a bad open circuit she would still spark while cranking but stop sparking if not.
Chesk the igniiton switch,,,,, ,,,,,try to hot wire the coil,,,,, ,,,,insure the ballast is in place n wired correct and NOT burned up.
If needed I will post my entire troubleshooting procedure for non sparking but you gotta get voltage to the coil before shes ever gonna fire..... .
lemme know
John T http://good-times.webshots.com/album/554031836ecRtCj
55 50
12-02-2006 19:45:27
 Re: Ignition Switch on JD70 in reply to John T, 12-02-2006 19:29:40
John,
If the switch is good and turned on, the output terminal (IGN) to the ballast resistor should read approx 12 volts regardless of the points being open or closed. The meter will be between the voltage source and ground and that's all that's needed for getting a 12 volt reading assuming the switch is good. Ron
John T
12-03-2006 06:30:51
 Re: Ignition Switch on JD70 in reply to 55 50, 12-02-2006 19:45:27
Ron, I agree with your answer (as you say if switch is good) but concerning why its still best to measure the voltage WITH POINTS CLOSED, heres my thoughts FWIW.
Youre exactly right "IF THE SWITCH IS GOOD" I.E. NOOOOO RESISTANCE ACROSS ITS CONTACTS BUTTTTT IFFFFF FFFFF the switches contact is carboned up, weak, orrrrr r resistive (the whole thing about a bad switch)????? Thats why I like to measure the voltage with THE POINTS IN PLACE AND CLOSED, cuz if they are open the unloaded output voltage on the IGN terminal dont really tell you all that much, assuming a decent quality meter with highhhhh hhhh ohms/volt.
I should have been more precise cuz if a guy had a good voltmeter and good conenctions (with points closed) I would expect to see maybe 12.6 volts at the switches BAT input and maybe 12.5 to 12.6 on its IGN output HOWEVER WITH THE POINTS CLOSED if the IGN terminal voltage is maybe down to only 12 volts,,,,, ,,,,, ,then I suspect a carboned up or burned resistive switch BUTTTTT TTT without the points in place and wired, such a voltage drop (from a bad switch) would NOTTTTT TTT show up, right????? ?
I enjoy this tricity chat, good post, take care yall
John T
John T PS
12-03-2006 06:42:54
 Re: Ignition Switch on JD70 in reply to John T, 12-03-2006 06:30:51
PS, I guess what Im saying is a lot of so called "bad switches" Ive observed were ones having carboned/loose/resistive/intermittent contacts causing a weak or no spark (from low coil voltage) VERSUS ones sooooo o baddddd dd there developed a complete OPEN CIRCUIT through the contacts, in which case there would be nooooo voltage at all on the IGN terminal REGARDLESS if points open orrrrr closed. Voltage measurements with them closed, however, allows such switch fault or weaknesses to show up
Fun discussion for us at least lol
take care John T
55 50
12-03-2006 10:19:31
 Re: Ignition Switch on JD70 in reply to John T PS, 12-03-2006 06:42:54
Yes going into this a bit deeper, you"re correct with the points (no pun here!) you made. Recently I worked on the lights on a 720LP and found that voltages on the light terminals of the switch and with bad grounds AT THE LIGHTS, there was usually between 11 and 11.6 volts at the switch terminals, tractor not running and voltage at the battery hot (-) terminal of just over 12 volts. I have an excellent meter in a Fluke 73 III (at least I think it"s an excellent meter) which was my retirement gift from my employer. So your points of some resistance and corrosion buildup in those switches as they age is well taken. Thanks. As you say, fun discussion.
Totally different subject: Did you see the entry on one of these forums where a fellow was having trouble with a caster wheel that wouldn"t caster? Some one responded that maybe it needed some castor oil!!
John T
12-03-2006 14:46:45
 Re: Ignition Switch on JD70 in reply to 55 50, 12-03-2006 10:19:31
Love the Castor Oil story, them bad switches need some sort of oil lol I doubt one could get any contact cleaner into where its needed but the problem is usually the springy (ness) is wore out n the wiper and contacts just dont fit snug no more. As I get older I experience similar problems..... ...
John T
